Results 1 to 11 of 11
Thread: JZX83, overfueling, engine light comming on
    Tasmania
    Default JZX83, overfueling, engine light comming on
    Hey people, i have done a search, but couldn't find anything to help me out.
    I have a 92 cressida with a 1jzgte auto conversion
    it has a SAFC and SITC but are both running on zero, also exhaust is only running to the dump/front pipe at the moment.
    my problem is it will randomly stall due to over fueling, if i sit ideling, then go to take off it will stall randomly and is very hard to get restarted (restarting results in a huge smoke cloud)
    also idle randomly can be very low (around 500rpm) and will over fuel, while it is doing this if i disconnect the map sensor it will idle fine.
    also, the engine light will randomly flash up, and if i get below 1500rpm after it has done this and i accelirate it will stall, but if i turn the car off and back on it will be fine
    because the car is only doing it randomly (hot or cold, doesnt matter) im stumped
    any help would be great
    thanks heaps
    -Jake
    Default Re: JZX83, overfueling, engine light comming on
    Have you checked the "leaky ECU capacitor" threads on here?
    Have you pulled codes from the ECU to see why it was flashing?
    Tasmania
    Hey Jake the caps have been done in this ecu so it "should" be something else, maybe the line to the map sensor is split a little or maybe blocked? I got the old caps back and could see where they were leaking but it may be other caps in the ecu?
    Tasmania
    Cheers, Rich and TLSF, i have opened up the ECU and all capacitors have been replaced and are 100% fine
    i replaced the line going to the map sensor and it made no difference
    how do i check the ecu fault codes? i didnt see any lights on the ECU (like my old car had)
    Thanks again
    -Jake
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Dec 2006
    Try get the SAFC tuned?
    That may be coursing it? Try and run it with out the SAFC and see how it is off?
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Tasmania
    even with the safc at turned right down it still over fuels badly on idle randomly
    to run without the SAFC can i just disconnect it? or would i need to rejoin the loom?
    -Jake
    New South Wales
    id still swap the ecu just to be sure, cause i had the capacitors replaced in my ecu and they said no guarantees, so then i got another ecu and problem solved.
    just recently a guy had an issue with no boost and running rich, think cause he had the boost control wire the wrong way.
    id try and get the engine codes up if u can
    Tasmania
    will try and get another ECU to test
    how do i get engine codes up? im used to nissan ECUs with the lights on the ECU and a diagnostic switch, EFI toyotas are new to me
    -Jake
    Tasmania
    Junior Member Backyard Mechanic MOOKIE's Avatar
    tas
    hey marshmallow !
    lloyd has ronnie now he might be able to lend u the ecu out of that unless dan still has his ???
    has nick looked at it yet ?
    Tasmania
    Cheers for that Rich, will check the ecu codes on sunday,
    Sweet as Mookie, i will get onto lloyd Dan doesnt have his old ecu
    havnt got Nick to look at it yet, would be lucky if i could drive it that far at the moment
    --Jake
  1. Toyota BEANs, Multiplex etc
    Last Post: 14-12-2016, 06:21 AM
  2. GUIDE: ISCV Wiring / M-REL Wiring
    Last Post: 17-07-2011, 02:36 PM
  3. JZA80 check engine light and hazard light coming on randomly
    By VasH in forum Tech and Conversions
    Last Post: 24-10-2008, 12:24 AM
  4. MA70 --> JZA70 Conversion
  5. 1ggte, wont idle on cold start. check engine light on
    Last Post: 11-06-2007, 07:03 PM
