Has the problem just appeared or is it you've never been able to tune it to run without knock at that boost?
If just appeared and nothing else has changed then I would go with fuel swap/check plugs etc, or check someone hasn't sat on your laptop and put a rouge fuel/timing setting around that area in the map.
If you've never got it to run the 18psi w/o detonation give it fuel!! 12:1 IMO is no where near enough, esp if you have a relatively small exhaust housing.
