Results 1 to 2 of 2
Thread: 200mm clutch on 4agze???
    Feb 2009
    western australia
    Default 200mm clutch on 4agze???
    ok i need some advice quickly!
    i have an mr2 with a 4agze which uses the 225mm clutch standard. for cheapness and availability of parts i have decided to use a 200mm clutch/flywheel setup. i have just purchased a toda flywheel, and am on the exedy website and it seems that the spline OD for the 225mm is different to the 200mm. have a f**ked up here. will a 200mm clutch not suit the standard gze gearbox??
    matt
    Victoria, Mt Macedon
    Default Re: 200mm clutch on 4agze???
    The standard 4AGE 200mm clutch will not match the GZE box splines.
    However you (or a decent clutch shop) should be able to find an off-the-shelf clutch that is 200mm in diameter and matches the GZE box input shaft. I think it's an old Landcruiser, Hiace, Hilux or Liteace that suits.
    Or failing that, you can get a clutch plate resplined to suit.
    Hen
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. *HELP* [TA23] New Excedy Clutch Won't Dissengage
    By RAAAH23 in forum Tech and Conversions
    Last Post: 22-05-2010, 10:22 AM
  3. 4agze utilising ge fly and clutch.
    By Biggo in forum Tech and Conversions
    Last Post: 02-07-2007, 12:12 PM
  4. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 09:12 AM
  5. Clutch fork problem
    By Spode in forum Tech and Conversions
    Last Post: 21-08-2006, 10:30 PM
