Results 16 to 27 of 27
Thread: Boost Controller - Pro's & Con's
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    Default Re: Boost Controller - Pro's & Con's
    im running full 3in exh and turbosmart boost tee@15psi and am not seeing any boost or fuel cut?! or am i just not pushing my car hard enough lol
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    Junior Member Domestic Engineer 1jz68u's Avatar
    if you are hitting 15psi it would suggest to me that your fuel cut has been removed as it should cut at 14.5psi
    Glenn
    Current Ride http://www.toymods.net/forums/showthread.php?t=41123
    Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
    Quote Originally Posted by NME308 View Post
    You do of course realize forgiveness is easier to gain than permission right???
    Cheers, Jason
    Apr 2008
    jzz30 stock ecu... emanage blue with a minimal base map i found on the net... how would i know if i had the fuel cut?
    BURN RUBBER
    if you got the map off the net ask the person that made the map.
    i would suggest however though that it has either been raised or removed completely.
    if in doubt you should be able to send the map to cihan (http://www.etuner.com.au/) i think his name is and he should be able to tell you.
    Glenn
    Cheers, Jason
    Quote Originally Posted by 1jz68u View Post
    with the safc (piggyback) as soon as you remove fuel from the map (lean it out) it will raise the boost cut (piggyback = sensor bender). i would assume here that this also applies to your emanage... hence the higher (or removed) boost cut.
    iirc boost cut is at 13.5 or something isnt it? pretty sure it was below 1 bar (14.5)
    JZA70|R / 12.45 @ 111 mph.
    e-manage blue has a "Boost Limiter Cut Settings" table
    The below table is just an example, it's not mine, I never used it, etc, etc
    Wilbo's JZA80
    Wilbo's JZZ12
    Selangor
    Great info all, thanks
    Jun 2009
    Cheap option which has turned out a very good option has been a "Turbotech" ebay ball and spring MBC.. always holds boost well and doesnt spike.. used upto 17psi and was fine.. now using it with a garrett and still no probs.. thought of upgrading to an EBC but only if it makes a significant diff to spool. but doesnt sound like it does..
    90' GT-Four ST185 RC motor ST205 gearbox!
    New installs Ct20B and Rear Strut Brace!!
    Next to come;
    3SGE cams, Fidanza Adj Cams, WolfKatz fuel rail!!
    Jun 2008
    victoria
    Quote Originally Posted by obrim View Post
    I use Gizzmo MS-IBC. Very cheap and easy to use. Doesn't have a nice little GUI but does the job.
    +1 for the gizzmo, its not half bad
    Mk3 Supra - 7mgte, Haltech, T61 - 411rwhp @ 16psi
    +1 for turbosmart eboost 2 very easy to set up lets me run close to boost cut on my 1jz. easy to select between different setting, has wastegate control, and its easy to set up. Said it twice cuz its really easy to setup. Tried a manual boost controller ie ball and spring and it was rubbish. Would probably be ok on a car running decent boost and the absolute value isnt important. But if you want close control to a psi thats always the same regards of temps load etc it has to be a EBC.
    i got my eboost2 for $300 practically brand new so pretty good price for what you get
    Jun 2008
    victoria
    Quote Originally Posted by wilbo666 View Post
    Looks dangerous =P
    I'm of the opinion that the best way to fix it boost cut is to remove the TCCS completely.
    Nov 2010
    I didn't have much luck with the simple bleed valve type boost controllers. I've attached a dyno graph from my last car which ran an RB20 fitted with a simple turbosmart bleed valve boost controller, and GT2871R. You can see the dynamic behaviour of the valve as it tries to regulate boost. The spike and subsequent undershoot made a noticable effect on the power output both on the road and the dyno. The graph shows three runs at different boost levels.
  1. a GOOD electronic boost control
    By renxun in forum Tech and Conversions
    Last Post: 27-01-2009, 02:54 AM
  2. Trying to wire up solenoid valve to boost controller?
    By trd-st162 in forum Tech and Conversions
    Last Post: 21-11-2006, 09:35 PM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 11:16 PM
