Results 1 to 9 of 9
Thread: Clutch Master Cylinder - Need As Short As Possible
    New Zealand
    Default Clutch Master Cylinder - Need As Short As Possible
    So what is available and how short?
    The V8 in my KE70 Corolla Ute is leaving me very little room, 35-40mm head to firewall but have another 15mm to the actual pedal box so can easily recess through the firewall. Most I have looked at are around 80mm (AE86, AE82 etc) so any ideas ideas on something shorter that can be adapted will be much appreciated.
    Callum
    Default Re: Clutch Master Cylinder - Need As Short As Possible
    what about something out of a van? Hiace etc... how about a bell crank, to turn the M/C 90 degrees?
    I recently fitted a pajero clutch master in my ra28.. was heaps shorter than factory unit.
    I can get exact measurements tomorrow if needed.. But a lot more of the body protrudes inside and basically all that sticks out of the firewall is enough for the fluid bowl.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    New Zealand
    Measurements on that would be good Joel, looks like it might be a little long though. This is the space I have to work with -
    Callum
    New Zealand
    No I hadn't cheers for the link. Still looks too long though, remote mount reservoir was already the plan.
    Callum
    Apr 2007
    As has been mentioned you might have to go a bell crank & turn it 90 degree & actually mount it inside the cabin with a remote reservoir outside ..
    The other option i thought is to remove the cam cover & actually notch out a section in it & re-weld to give you the clearance, obviously make sure that it wont foul on anything inside the motor though ..
    Looks like the Brake booster is going to be a tight squeeze too ..
    Use a reverse set-up - Instead of the brake lever being hinged at the top and the pushrod going forwards through the firewall, hinge the pedal down a little and have the pushrod & master cylinder coming back into the cabin. A bit tricky to build & fit, but they work.
    Like this ->
    Either that or have floor-mounted pedals and have the master cylinders sitting low ->
    www.billzilla.org
    Toymods founding member #3
  1. 96 Vienta clutch slave cylinder
    By zydawn in forum Tech and Conversions
    Last Post: 20-05-2009, 04:55 PM
  2. RT104 corona clutch slave cylinder
    By StuRT104 in forum Tech and Conversions
    Last Post: 17-05-2009, 06:32 PM
  3. Brake booster and master cylinder KE30
    By shy_77c in forum Tech and Conversions
    Last Post: 31-05-2006, 06:18 PM
  4. MZ20 brake master cylinder
    By Bored? in forum Tech and Conversions
    Last Post: 17-05-2006, 11:08 AM
