Results 1 to 2 of 2
Thread: 22r turbo wiring help
    wa
    Default 22r turbo wiring help
    So im thinking to do a 22r turbo on my daily hilux as ive had it with it being slow.
    I have a corona intake manifold for it and i have a spare adaptronic ecu sitting around so i was wondering how to set up the trigger side of the ecu.
    Will i have to make up a trigger wheel and cas for the crank or could i get the signal from the dizzy.
    I know its not going to be a weapon but it will just help a little.
    Default Re: 22r turbo wiring help
    - source the guts of any 22Rx dizzi that has electronic ignition
    - remove any vacuum advance/retard hardware (and lock the upper plate)
    - remove any mechanical advance hardware and lock the upper and lower sections of the rotating bits together
    - fit to engine
    you now have a 4 tooth VR trigger wheel.
    read the ECU manual regarding when (in time) the ECU needs to get a trigger signal. This will guide you on how to position the dizzi and get the rotor pointing correctly.
    Last Post: 03-05-2009, 06:47 PM
  2. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  3. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 07:58 PM
