Results 16 to 23 of 23
Thread: Urgent advice required - car broken down on road
    Jan 2007
    queensland
    Default Re: Urgent advice required - car broken down on road
    side tipic -
    don't be scared with a bit of a degrease and a squirt with a water blaster every now and then... just don't aim for things like the dizzy... i always degrease my engines HOT, and in any case possible with the engine running... (sometimes pod filter setups won't allow this) and have a can of WD-40 handy.. water shouldn't get into places it should not be... if it does.. might be a good time to look at replacing that gasket (like the thin one that 'seals' the cap to the dizzy)
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    Quote Originally Posted by pandaah View Post
    very common on the 5sfe mate.. its your ignition coil, these are removable from the distributor...
    place motor on TDC piston number 1 and whip the dizzy out (dont be too stressed its a slotted dizzy that only goes one way), theres 2 bolts holding it in (the ones you loosen as if you were going to adjust your timing), take the cap off, and take the rotor button off and dust cover, from memory theres 2 little nuts holding wires and 4 screws holding the coil to the dizzy..
    bobs your uncle
    Pick up coil?
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    For future reference, to test the fuel pump on an EFI corolla, grab a test light and a piece of wire to use as a jumper. Locate the CoR (circuit open relay), turn the ignition on, but don't crank it. Test the wires on the CoR, one will be live. Use the wire to jump this the wire going to the fuel pump. If you don't here the pump running then locate the fuel pump plug and test the connection there. If the connection is good, use the test light on both sides of the connector, your fuel pump is probably shot.
    Had to do this about 2 weeks ago, Turned out I had a dodgy connection just before the pump.
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    Aug 2009
    Quote Originally Posted by punkture View Post
    Pick up coil?
    no the actual coil, with the primary and secondary windings inside...
    Apr 2008
    ah kk the usually cylinderical ones on old vehicles??? how are they behind the dizy? thought theyd be on the firewall
    Aug 2009
    nah, the 5sfe engine has the coil inside the distributor, its only pritty small... its got an electronic pickup that is used to tell crankshaft position and thats what triggers the coil to fire inside the distributor, then the coil itself fires directly into the cap...
    ill try find a picture of one
    Aug 2009
    http://inlinethumb33.webshots.com/46...600x600Q85.jpg
    heres an extremely large close up of inside the dizzy with the rotor button and dust shroud removed.. the orange thing with toyota and the part number written on it is the coil.. the 3 with the arrow is where the coil fires to directly into the distributor cap which is sent via the cap to the rotor button
    Apr 2008
    ahhhhh you leanr something new everyday! =) +rep for you haha
  1. TA23 Mechanical advice required
    By mr_unix in forum Tech and Conversions
    Last Post: 30-06-2007, 09:26 PM
  2. Urgent: MX73 front sway bar dia. required
    By BigWorm in forum Tech and Conversions
    Last Post: 31-05-2006, 05:04 PM
