I had a Gemini once (that's probably a nasty word around here but anyway) It had a modified g200 (2 litre) log style manifold and a turbo of similiar sort of size that you are refering to. It had a blow through style carby of some sort off a renault or peugeot (can't remember what model off the top of my head) and it went extremely well.
I did approx 50,000km with that setup and found it was no problems once it was setup initially. The biggest problem I had was when I was orginally setting it up I wanted to run 10psi+ but during the setup stage I found with the biggest available jets for that type of carby I could only get about 8psi out of it before it became to lean.
I guess where I'm going with this is try and choose a carby that is quite common and uses the same style jets as other models that require more fuel flow. There were options I could have gone down to overcome jet problems such as resizing or custom made but it all became to hard so I just stuck with what I had. Other than that it was a good setup reliable and only very minimal tune changes where required to keep it running well.
I hope that helps
Aaron
