1uz ftw
if not then 3rz-TURBO
see now that sits with the boys
neil
Hey Guys,
Im after some input and your opinions on the two engines im looking at. Im going to be taking out the standard 22R and wanna replace it with something that has ait more go![]()
Talking to a couple of mates at boys night and some of the guys brought up some good sugestions. I was orginally going to go for a 1G but then they brought up a good point of then going to register the car it will be under a 6cyl so abit more expensive. So now im looking into the 3RZ as a nice 4cyl alternative.
I know that im going to need to fabricate up my on engine mounts either way i go as well as from what i have read as long as i use the 1G or 3RZ bellhousing it will mount upto my standard gearbox.
These are the specs i have pulled up.
Engine
22R - 81kw @ 5000rpm - 187Nm @ 3400rpm
3RZ-FE - 112kw @ 4800rpm - 240Nm @ 4000rpm
1G-GZE - 125kw @ 6000rpm - 226Nm @ 3600rpm
so basically the only downside of going for the 3RZ is that it has less power. But it has in favour for it thats it's a square motor with a stroke height of 95mm and a bore of 95mm. as well as making most its power down low.
Whats your take on it guys,
Input is much apreciated
1uz ftw
neil
2009 aurion
Purple 2000 Hilux - 1UZ![]()
Rego doesnt matter going from a 4cyl to a 6cyl in a Commercial Ute.
They charge registration on what the vechile is legally allowed to carry.
Means you can drop in a V8, with no issues about it costing you more.
Herus
