Results 1 to 6 of 6
Thread: 4af misfire
    Apr 2010
    Default 4af misfire
    hi, ive just installed a 4afc motor in my girlfriends corolla. i took it to trade school today and timed it up properly, and on the way home tonight it started misfiring when i was almost home. it only seems to happen intermitedly, and while the engines revs are low and its under load (putting my foot down at about 10kph or so, sometimes faster).
    i think its the plugs, just wondering if that is the most likely cause, or should i be checking elsewhere.
    Sep 2009
    Default Re: 4af misfire
    Check for vac leaks ect..
    Replace plugs/rotor cap and button.
    Probably wouldn't hurt to do the fuel filter either.
    If that doesn't help, buy a timing light and see if the timing is out and if it is set it back to factory spec.
    if that doesn't help, install a 4azge.
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    Sounds like your leads need replacing, check for resistance in all the leads you will find that one will be opengiving you a reading of zero, change the plugs while you are there,
    I would also check the cap & rotor and the coil
    Apr 2010
    ok, thanks. i was going to check the leads anyway, and i have a spere set off the other motor anyway. was just wondering if there was anything else to check, but ill just do these tomorrow.
    Nov 2009
    tasmania
    did you happen to wash the engine bay at said trade school?
    Apr 2010
    nope. just timed 'er up. seems to do it when cold, and then just randomly at low throttle openings.
    ill check all i can think of tomorow
  1. 4agze misfire
    By LO01UX in forum Tech and Conversions
    Last Post: 25-09-2009, 03:38 PM
  2. 4A-GZE Overboost, followed by misfire or knock.
    By 88AW11SC in forum Tech and Conversions
    Last Post: 14-05-2008, 05:26 PM
  3. 1JZ into MX83 misfire at 3k rpm
    By Yammies in forum Tech and Conversions
    Last Post: 27-01-2008, 03:55 PM
  4. 3s-fe misfire
    By ecko in forum Tech and Conversions
    Last Post: 21-05-2007, 05:32 PM
  5. Misfire / Running on 2/4cyl 18RG help.
    By TA-022 in forum Tech and Conversions
    Last Post: 20-01-2007, 12:41 PM
