Results 1 to 3 of 3
Thread: 1uz ecu temp sender?
    Jan 2008
    queensland
    Default 1uz ecu temp sender?
    Anyone got the part# of a 1uz ECU temp sender(not the single wire one that is for the gauge). I tried a search and came up with nothing, i think my sender or sensor is playin up, a few months back the fast idle stopped working when engine is cold so i pulled apart the iacvalve and cleaned/greased it, think i replaced 1 of the roller bearings cause it was in stock and cheap as but both felt near new anyway, this all made no change whatsoeva so i was about to look at the temp sensor back then but it all of a sudden fixed itself until thismorn. I have read other posts where the resistance can stuff around without logging a code so i'm pretty sure its the culprit, all i need now is a part# to test my theory, thanx guys...... MICK
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Default Re: 1uz ecu temp sender?
    From: http://www.toymods.org.au/forums/sho....php?p=1091764
    Quote Originally Posted by AndyTTR View Post
    ... I bought a genuine Toyota one, cost $65 iirc. p/n 89422-20010
    Its just a generic Toyota EFI Coolant Temp Sender, I think somebody mentioned in the thread that they got one for about $20 from Supercheap?
    Jan 2008
    queensland
    Thanks mate that is exactly what i needed. Havent noticed any bad fuel economy yet but its only just happened today, i do about 32ks each way to work and usually get a week and a bit out of a tank in me hilux,see how it goes.
  1. Water Temp Sender
    By MarioM in forum Tech and Conversions
    Last Post: 09-01-2007, 09:11 PM
  2. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 07:31 AM
  3. RA/TA2x oil temp gauge sender..
    By celica-fiend in forum Tech and Conversions
    Last Post: 30-01-2006, 01:57 AM
