Results 1 to 15 of 18
Thread: st185 3sgte changed battery now back fires
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    Default st185 3sgte changed battery now back fires
    Hey, on saturday i drove the car, and all was fine, then tonight went to start it and the car wouldn't start, found it was the positive terminal was loose, reconnected and was fine, drove it for roughly an hour and was fine, turned it off, started it back up about 1hr later and drove it was fine for 10min then started back firing and losing power majorly..
    Default Re: st185 3sgte changed battery now back fires
    Did you move around the AFM plug at all?
    Check for ECU error codes.
    Apr 2008
    yeh battery is in boot =p hadnt touched the afm at all..mwp, when it was blazing cold tonight i started it up and tryed to drive, it went then as soon as there was a tad bit of load died in the ass..ecu being gay? im getting fuel filter, oil filter, oil and plugs tomorrow.
    Okay the bgb's LCM was ignition timing and vaccuum leak?
    Could be anything, will have a look tonight.
    Apr 2008
    sweeet cheers =)
    Apr 2008
    okay replaced dizzy cap, waiting for brand new one got a second hand one and is a little better, but its still hunting idle at ~400-~800rpm, and missing a bit..very not happy =(
    So how well did you check it over before buying it?
    Didnt you say it had an RAA check too?
    Aug 2009
    you tried tapping the TPS or idle control valve?.. sometimes after a battery change they go abit funny, or yours could be sticking... engine light isnt on or something like that?
    Apr 2008
    MWP, ran perfectly when i drove it for 20min before buying it, let it idle, drove it again etc, RAA said it was fine, drove it home perfectly too, just started happening when the battery came loose, but im thinking it was coincidence.
    pandaah, ill have to try that tonight, judging from the fact that putting the better condition cap made her run smoothly makes me think its definately ignition related, ill put the new cap on thurs, and getting new leads today as well. what are the part numbers for the leads?
    Add Lightness! Grease Monkey spectral's Avatar
    I'd agree its probably a co-incidence.
    Did you get the codes first as MWP suggested? I'd do that before throwing more money on leads and other replacements you may not need.
    Westfield Clubman SEi - 4AGE Blacktop, T50
    RN90R Hilux XtraCab - VT V6 (yeah yeah) ,4L60-E, 3.583 LSD
    Apr 2008
    wont give me codes..?? im using a paper clip, wires everything lol. i put the car on idle after running it, then jump te1 and e1 and no idle change and no cel?
    Its TE2 and E1!
    With the car off, bridge those two, then turn on igntion, but dont start the car.
    Count the check light flashes.
    Apr 2008
    ghhhrrrr still nothing, i swear this car is retarded..
    Apr 2008
    when you dont start the car and its on on only the cel should be displayed yeah? mine isnt..FML
    check that there is a bulb in it. They may have removed it to sell the car so the light wouldn't be on when ppl test drove it
  1. blue phosphurous stuff from leaking battery
    By HAVABEER in forum Tech and Conversions
    Last Post: 21-07-2008, 08:15 PM
  2. Alternator/Charging issues.
    By DoctorDubb in forum Tech and Conversions
    Last Post: 07-03-2008, 05:44 PM
  3. 3sgte timing belt issues st185
    By danny2 in forum Tech and Conversions
    Last Post: 19-02-2008, 07:20 AM
  4. Stock/Standard JZS147 Aristo Battery CCA Rating?
    By Esteban in forum Tech and Conversions
    Last Post: 09-10-2007, 07:40 AM
