Get a length of metal rod... aluminium.. about 5 to 8mm in diameter. Use those screw-in clips, attach the rod to one of the extractors, and bend the rod so it has about 2 or 3 lots of 300mm length attached (ie double or triple the rod back on itself a few times), and then put the end of the rod into where the auto-choke went (ie from the original manifold).
The whole point is to have enough alu rod on the extractors so it gets hot and that heat goes into where the old auto-choke was so it can go off-choke as the rod heats up.
It's hard to explain. I may have a pic of Trini's old 18R-C somewhere, when she had extractors and this was used to make the auto-choke run as per normal.
seeyuzz
river
