Results 1 to 3 of 3
Thread: r154 oil
    Oct 2007
    Default r154 oil
    How do you check/ top up the oil and what oil should I use
    Jun 2007
    Default Re: r154 oil
    There is a plug that screws into the left hand side of the gearbox that you unscrew to check the level. When you unscrew the plug oil should dribble out if it is full. If oil doesn't come out you should be able to stick the end of your little finger in the hole to see how low the level is. Use 75W80 or 80W oil. If you use oil any thicker than 80W you will have trouble changing gears in cold weather until the oil warms up.
    You fill it up through the hole on the side with a pump.
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    VMX80 all the way
  1. r154 shifting experiences
    Last Post: 24-11-2009, 09:47 PM
  2. R154 Selector Forks.
    By Turbomini in forum Tech and Conversions
    Last Post: 17-07-2009, 04:30 PM
  3. R154? Good or no good?
    By TTV8RA23 in forum Tech and Conversions
    Last Post: 12-02-2008, 09:18 AM
  4. R154 gearboxes
    By AEhachiroku in forum Tech and Conversions
    Last Post: 06-09-2007, 01:38 AM
  5. R154 Rebuild Questions
    By delazy in forum Tech and Conversions
    Last Post: 22-08-2007, 06:14 PM
