Results 1 to 4 of 4
Thread: Can i swap 3rd gear from W55 into W58?
    Perth, WA
    Default Can i swap 3rd gear from W55 into W58?
    Is there any one done it before by swapping W55's 3rd gear into W58 gearbox? W55 seems a bit of rough and W58 is a bit on the taller side around 3rd gear ratio.
    W55 3.566 - 2.056 - 1.384 - 1 - 0.850
    W58 3.285 - 1.894 - 1.275 - 1 - 0.783
    After the swap will be
    W58 3.285 - 1.894 - 1.384 - 1 - 0.783
    Any one?
    Default Re: Can i swap 3rd gear from W55 into W58?
    Unfortunately, the difference in the ratios is from a difference in the layshaft gear ratio - all other gears have the same number of teeth so changing one pair wont change the ratios.
    Quote Originally Posted by CrUZida View Post
    Incase anyone is interested I got bored and calculated all the teeth.
    W55
    Layshaft - 47/32 - 1.469:1
    1st - 34/14 - 3.567:1
    2nd - 35/25 - 2.056:1
    3rd - 33/35 - 1.385:1
    4th - 1:1
    5th - 33/57 - 0.850:1
    Rev - 39/14 - 4.092:1
    W58
    Layshaft - 46/34 - 1.353:1
    1st - 34/14 - 3.286:1
    2nd - 35/25 - 1.894:1
    3rd - 33/35 - 1.276:1
    4th - 1:1
    5th - 33/57 - 0.783:1
    Rev - 39/14 - 3.769:1
    http://www.toymods.org.au/forums/showthread.php?t=1148
    Looks like the gears on the mainshaft are the same ratios in both boxes with different ratio on the input shaft gears to give different end ratios (closer)
    Jealousy is a curse
    vic
    One problem i have come accross twice , once with a W box an another G box , is that toyota had different companys make the boxes over the years and a gear out of one sometimes wont fit another . Diffferent gear cuts .
    Dave
  1. W5x aftermarket short ratio kits? Anyone got any leads?
    By irishtwincam in forum Tech and Conversions
    Last Post: 17-02-2008, 10:05 PM
  2. Dyno in third gear? ( W58)
    Last Post: 26-06-2006, 06:36 PM
