Results 16 to 25 of 25
Thread: hilux lsd diff options
    Default Re: hilux lsd diff options
    Quote Originally Posted by Jordan 76 View Post
    reason i ask is the lux diff i had in the celica had a brand new tru track lsd fitted the same time it was re-built and the lsd didnt last long before it started opening up from time to time and to be honest i wasnt too happy. Ive heard its fairly common for clutch type lsd's to do this, correct me if im wrong?
    You're not incorrect, clutch LSD's wear out. A Truetrac should never have this problem, it should just...break.
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    arb diff lock........... On and off lsd. Good if ya making a lot of power and helps in wet weather around the suburbs.
    Its on my list of shit to get
    Junior Member Grease Monkey greg's Avatar
    Jun 2007
    Smile Re: hilux lsd diff options
    Curt,
    Stitt is correct, the LSD was only fitted to the cressida grande in the mx83. There is a modification that has been detailed on this forum to strengthen them and i would suggest that you speak to someone that has done this mod before you use one. I have 2 of them and will test the one in my grande when i (if I) get the2J conversion finished ,the car has only done 98K.even so i intend to order a tru trac before i even try it.
    My 1uzfe cressy has a KAAZ 2way lsd ,which has copped heaps with no sign of slip although it is a bit savage.ie tends to chirp in tight turns.this is a stock 1uzfe. you need to decide what power you are going to run and then decide what you need to put it on the deck.
    Cheers Greg.
    Brum,was going to be a billy cart ,now has motor and 6 speed+++
    1uzfe Mx83
    2jzgte MX83
    working hard Backyard Mechanic
    Quote Originally Posted by millsi View Post
    i used a 3.7 centre from a ma70 auto turbo, just took both centres to the diff shop and got them to make 1.
    lsd spins up 2 every time in a straight line but only ever 1 when coming out of a corner.
    can an lsd be welded up?
    the 3.7 ratio is good but a 3.5 would be better. just super hard to find.
    Is it possible to weld the LSD center? Or even tighten up the supra LSD . Mine locks up when it feels like it and find it very unpredictable.
    Dreamer Backyard Mechanic millsi's Avatar
    apparently not.
    all good though, a full spool is only around $250
    I and wanting to do this myself I can weld fine but not to sure about setting up a spool with my LSD gears and setting up backlash etc. Reason for welding my LSD
    Jun 2007
    Hi.
    If you wish to weld a diff , use a stocky, no point in welding a LSD. This will be great if you only want to use it on the strip, if however you wish to use it on the road you will find it does not do much to enhance the handling ,particulaly in the wet,more power ,more probs.
    Cheers greg
    1uzfe Mx83
    2jzgte MX83
    Hey fellas hate to hijack but im pulling my hair out, and havn't heard about the exact issue that I am experiencing with a similar mod!!! I have a hilux diff that im planning on putting in my TA22, (RN25 housing) that originally had a 4.7 ratio in it. I have gone off and bought a detroit tru track centre and also bought a JZA70 centre with a 3.9ratio to swap into my huilux diff..
    All the parts have been given to my diff guy thinking it was all bolt together, however he seems to have clearance issues as the pinion gear is too big to fit within the actually hilux housing?? He seems to think that there are 2 types of hilux centres and becuase I started off with such a tall ratio it won't actually fit within the centre.... I have given him some links to toymods re people using spacers to space out the crown wheel which will inturn fix issues with the pinion adjustment, however he seems to think that the opposite adjustment is needed and the pinion is physically too big?? Has anyone heard of this?
    Do I need to ditch the JZA70 ratio and go for some other G series centre with a different pinion size?
    See my 3T-GTE powered TA22:
    Click Here
    Currently running 192.8rwkw @ 20PSI
    I believe your exact problem is solved here; http://www.toymods.org.au/forums/showthread.php?t=27184
    A list of his combination is here; http://www.toymods.org.au/forums/sho...n25#post550089
    Cheers heaps old_school_jap1!! I will get on to my diff guy and try track down a hiace carrier in SA...
    Click Here
  1. hilux 'a' series diff?
    By jamesoarer in forum Tech and Conversions
    Last Post: 01-01-2010, 02:32 PM
  2. My Hilux Diff. WTF?!
    Last Post: 14-08-2007, 08:17 AM
