Results 1 to 15 of 25
Thread: hilux lsd diff options
    Junior Member Grease Monkey 81hilux09's Avatar
    Apr 2009
    Default hilux lsd diff options
    hay guys,
    since i have almost finished my engine conversion i have been driving it and have come to the conclusion that a lsd is going to be much more fun..
    the hilux is a RN41 81' 2wd.
    the rear axles have been modified to suit disc brakes so i really want to find something that will just replace the diff centre and bolt in. what models should i be looking for? will a 4wd one fit or are the axles a different size?
    thanks
    curt
    Toyota Hoarding Grease Monkey squish_m8's Avatar
    Sep 2008
    Default Re: hilux lsd diff options
    Hilux diff centres are G-series. same as what you'd find in MKIII supra's z20 soarer's etc. so there is a fair few options.
    cheapest would be just finding a stock Supra lsd and get it fitted or just weld your current one up
    Supra LSD will need a spacer get a Hilux LSD . I have a Hilux one with good clutches if you want one of them.
    Jealousy is a curse
    Apr 2009
    what do you mean by a spacer?
    i don't know much about diff's so all the info i can get will help heaps!
    would a mx83 cressida have a lsd? and would that fit?
    The IRS centres have a different offset behind the ring gear. Some MX83s have LSDs
    Jealousy is a curse
    Sep 2008
    mx83 grande's come with a stock lsd.
    If you take a g-series centre to a diff shop they should be able to swap it over for you.
    Apr 2009
    i can get a diff from a mx83 from the wreckers for $50 if i remove it myself.. so the shaft sizes on it should be the same as the hilux one?
    if there anyway of telling if its a G-series diff on the outside?
    good info guys thanks
    id like to jump in here and ask what type of lsd's people have been using in a lux diff and how happy they have been with them?
    reason i ask is the lux diff i had in the celica had a brand new tru track lsd fitted the same time it was re-built and the lsd didnt last long before it started opening up from time to time and to be honest i wasnt too happy. Ive heard its fairly common for clutch type lsd's to do this, correct me if im wrong?
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Jun 2007
    I was told that the Hilux LSD is not real good because they dont last long as a LSD. A torsen LSD would be much better. The torsen centre from a Supra needs a spacer between the crown wheel and diff centre if you use a hilux crown wheel. Detroit make a torsen centre to suit a hilux diff or you could use an auto locker centre like a Lockrite but it might be a bit difficult to stop the tyres chirping as you corner.
    I use a Supra Torsen LSD with the 3mm spacer ring between the diff centre and original crown wheel.
    Done 20,000 km so far and have had no issues at all. Best thing I ever did!
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Quote Originally Posted by Dazza View Post
    Question is this because the hilux is so heavy ? & in a celica there should be not problem with the hilux LSD centre?
    I got a Hilux LSD and it will not fit in my RN41 diff without cutting the axels, not sure if this is the case with other LSD centres?
    Manuel
    Apr 2009
    thats what i don't want to do.. i want an option to leave the axles intact and just replace the centre.
    Dreamer Backyard Mechanic millsi's Avatar
    i used a 3.7 centre from a ma70 auto turbo, just took both centres to the diff shop and got them to make 1.
    lsd spins up 2 every time in a straight line but only ever 1 when coming out of a corner.
    can an lsd be welded up?
    the 3.7 ratio is good but a 3.5 would be better. just super hard to find.
    Apr 2009
    ok guys,
    http://www.toyodiy.com/parts/p_G_199...FQ_4101.2.html
    this is a page of part numbers and info on the mx83 that is at the wreckers with a lsd in it.
    this is my ute diff with same info
    http://www.toyodiy.com/parts/p_G_198...-JRQ_4101.html
    is it possible to tell off that if they are compatible?
    thanks
    curt
    Act
    G series is G series all the centres are the same, same axle width, same splines, whether it is a Live or IRS centre, because of the shape of the IRS VS Live diff housing (for want of a better word) you need a spacer to run IRS stuff in a Live housing.
    However you haven't mention changing ratio's you should just be able to get the lsd centre fitted to your crown wheel and pinion, and have no issues.
    Me I would stay away from Clutch types LSD's well ones unserviced out of a older car they are going to be Fubar, they are atleast 20years old, and will probably single spin with a bit of grut through them. I run an F series true trak in my wagon atm and have just built and bought a G series True trak for the new G series going under there. Not sure what my diff guy did but I have a 3.9 from an IRS diff, fitted to the true trak in my Live housing.
    Also no where in this thread have you mention if the MX83 @ the wreckers is a Grande cause only the grande had the LSD im fairly sure.
  1. hilux 'a' series diff?
    By jamesoarer in forum Tech and Conversions
    Last Post: 01-01-2010, 02:32 PM
  2. My Hilux Diff. WTF?!
    Last Post: 14-08-2007, 08:17 AM
