Results 1 to 9 of 9
Thread: HEEEELLP! 88 HiLux with a 2Y and 4spd
    Feb 2009
    Default HEEEELLP! 88 HiLux with a 2Y and 4spd
    yes yes yes you read right - my 88 lux has a 1.8L 2Y and 4 spd box - i think it's an import but completely unsure - never seen a 2Y in a lux of this vintage anyway.
    chasing a 5spd box BAAAAAD and just found out my FIL has an older corona 5 spd floating around.
    what are the odds of the changeover being compatible?
    i have tried a search, but maybe someone could help with a more specific thread....?
    thanks.
    Feb 2009
    Default Re: HEEEELLP! 88 HiLux with a 2Y and 4spd
    it appears i'm running a W46, and the 5 speed in the corona is a W55.
    being all a W series box, is it at all likely possible that they will match up with no mods? what about the tailshaft?
    very hard to find info on the W46
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    well you would prob be able to swap over the bell onto the new box if its the same as all the W boxes, as for shaft id say it would be different but i could be wrong
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    You may have to change tailshafts, Its unknown.The w55 sounds like it will bolt up (W50 compatability)
    Even if you have to muck around with tailshafts it will probably be an easy fix. I changed an auto yn57 to manual, bought the box out of the paper and did not know what model, I suspect a w55. Auto tailshaft was not going to fit so a trip to just toyota wrecking and a few dollars and a tape measure fixed that. The thing you will have to watch out for is the shifter position to make sure it relates to the hole in your floor pan. Also there are several different types of rear gearbox mounts and they need to line up.
    should be an efortless conversion.
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    It depends if the W46 is a 4 speed version of the W5x, or a different iteration of the W40/W50 series.
    W40/W50 is not compatible (bellhousing wise) with the W5x
    Also normally 2WD boxes don't suit 4WD's (although not sure if your Hilux is 2 or 4 WD)
    Feb 2009
    sorry - yes lux is a 2WD.
    so the W5* box won't bolt to the W4* bellhousing.....?
    Jun 2007
    Your Hilux would be a Grinner by the sounds of it. They normally have grinner stickers on the front guards.Most of the Y series engines had a G52 five speed bolted to them but Grinners had a four speed box. It shouldn't be hard to convert to five speed because there are heaps of Hilux utes about with five speeds in them. If it is a column shift gearchange you could use a Tarago gearbox.
    Feb 2009
    no not at all - it's got this extension "thingo" running to the shift position from the gearbox.
    it looks VERY physically similar to the 'rona box.
  1. Hilux 22R to 22RE Conversion Help needed
    By MrBags in forum Tech and Conversions
    Last Post: 09-03-2013, 01:38 PM
  2. ra28 5spd into '83 hilux
    By BLACK77 in forum Tech and Conversions
    Last Post: 24-01-2007, 10:10 AM
