Results 46 to 59 of 59
Thread: ra23, home grown tubbing..
  1. #46
    Default Re: ra23, home grown tubbing..
    and as far as damaging the interior paint, why are you worried? its all covered up! As soon as you are finished letting it cool, just whack some rust proof paint from bunnings on there. (white night i used on my towbar - works great in a spray can) you will not have any corrosion problems whatsoever.
  2. #47
    I'm worried, Robbo, because it's LPG, NOT, Petrol...
    Facebook | LinkedIn
  3. #48
    i agree with stradlater, being safe is better than being sorry and not having a face
    whats the possibility of removing the tank tubbing then re installing?
  4. #49
    Unfortunately it's not a great possibilty, but might be something I can consider. The guy I'm doing it with is a fire fighter and he seems to think that it's not anything to worry about.. But, I'm still not so game
    Facebook | LinkedIn
  5. #50
    let him do it then
  6. #51
    I think I will be..
    Facebook | LinkedIn
  7. #52
    cover the tank in wet rags at least..
    if you are going that far.. why not mini-tub it?
  8. #53
    it's not got to go that far. Just a bit. But I do think it will need heat
    Facebook | LinkedIn
  9. #54
    dependant on where it is, it might be easier/better to make a cut with a angle grinder, and try to square off the arch with a hammer (if thats where its hitting) and then weld in some plate in the gap you create.
  10. #55
    New Zealand
    Try spacing the wheel out with washers or similar to see how much room you need, at least then you will know if the tyres can actually physically fit in there. If they do clear ok then you can look at either new wheels or even a spacer with longer studs. (No this isn't dodgy, it is actually quite common for race cars to do this and obviously slicks will only be for track use.)
    Callum
  11. #56
    it'd be no safer to use an angle grinder and a welder creating massive spark than using an oxy and a hammer...
    strad - dude you seriously wont have any problems. As i mentioned, if you are worried, remove the tank, plug the lines/ let the gas out and then go hell blazers. Then you know you Definetly wont have any issues....
  12. #57
    Yeah, grinding in the area with the LPG tank may not be so great either.. Well, it'll be looked into by this time next week, so I"ll take it from there.
    It may be that I get the guards heavily lipped and then plug away underneath with a hammer and oxy or something. I dunno yet. Just gotta get it done.
    Facebook | LinkedIn
  13. #58
    put your hand in the stream of sparks from a grinder, and put your hand in the flame of an oxy, report back.
  14. #59
    Hehe. I'd actually prefer not to be putting my hand in front of either if possible.
    Facebook | LinkedIn
  1. RA23 vs 2JZ-GTE
    By bugeyedcreepy in forum Tech and Conversions
    Last Post: 25-04-2006, 10:02 PM
  2. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
