what diameter are they?Originally Posted by Dispatcher
look up the hella site
or cibie
Anyone knows what upgrade i can get/use for a KP61 Starlet.Currently using sealed beams..are there halogen upgrades ?
Thanks Stewart on the cibie and hella site...
I'm also having problems getting replacement engine mounts & gearbox ones too....
any ideas if some other model mountings will work ?
Thanks all
Last edited by Dispatcher; 29-11-2005 at 05:24 PM. Reason: additional requirements
or cibie
Additional problems.!!.with getting engine&gearbox mountings...
anyone have an idea about any other models having a smiliar type mounting ?
Engine is 4K type.
from Purple Beasty
Starlet headlights can be replaced with semi sealed lights from later model Hilux and Hiace.
Also, engine mounts should be the same as KE70 (maybe KE30). Gearbox mount MAY interchange with KE20/30, well at least a KE20 4 speed bolted straight into my 84 KP61 but not sure if the 4 speed mount bolts directly to the 5 speed box. KE70 mount is different
Callum
Thanks Stewart..& Purple Beasty...great info.
now at least i'll have some choices.
Thanks for posting that Stu.
(changed name to match other forums since I had to re-register anyway)
Dispatcher, if you have any other queries just ask, or even check out www.club-k.co.nz for a wealth of Starlet info.
Callum
Hi Callum / WDE BDY...
Great info thanks....the K website..Tons of info...
appreciate it much.
Dispatcher
