Results 1 to 6 of 6
Thread: T50 Oil Viscosity & Amount Required For Change
    Apr 2010
    Default T50 Oil Viscosity & Amount Required For Change
    Hi Guys,
    About to do my first oil change on a newly acquired T50 gearbox. I was just wondering how much oil should i be filling it with on change and any recommendations as to brand and viscosity?
    cheers,
    Tom
    Default Re: T50 Oil Viscosity & Amount Required For Change
    Quote Originally Posted by thomen View Post
    Hi Guys,
    cheers,
    Tom
    about 1.5L, API service GL-4 SAE viscosity 90
    i normally use castrol 75/85 but thats cause i get it from work and its free
    Traditionalist Domestic Engineer parrot's Avatar
    According to the factory chassis manuals
    Early T type T50 1.54 litres
    Later A type T50 1.7 litres
    Cam mountain I feel different from the ordinary
    Apr 2010
    Thanks so much!
    im not too sure which t50 model it is.. I got it from dellow automotive to put behind a nissan a series engine!
    Tom
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    i use a 75/90 pennzoil in my T50 and i think it is about 1.5litres i just fill it till it trickles out then put the plug in, about 23 pumps of my pump at work (15 pumps=1Litre)
    Jan 2007
    queensland
    i use AFT dex 3 in all my T-50's unless they have fresh synchro's...
    they don't like changing smoothly above 7-8k behind 4a's unless you run thin oil...
    if it's a bit notchey or crunchy swap to dex 3.. and it will make a huge difference..
  1. How To: T50 Electronic Speed Sensor
    By Bazooka in forum Tech and Conversions
    Last Post: 12-11-2011, 05:51 PM
  2. T50 to AZ6..... At the CNC....
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 23-09-2011, 09:04 AM
