Results 1 to 15 of 26
Thread: hilux diff models.....which one?
    S.A
    Default hilux diff models.....which one?
    Im looking to do the hilux conversion into my cortina.
    Now i like to go with 3.9:1 ratio LSD. Id also like a disc brake rear if possible?
    I dont really have any ideas on the hilux diff appart from their known strength.
    So is there anything out their suiting my needs and if so what model hilux am i looking for ?
    IE what series. Im guessig fairly late for discs ?
    perth
    Default Re: hilux diff models.....which one?
    hey man,
    myne is from a rn41 from early 80's hilux 1410mm hub face to hub face and theres a 1375mm and 1440 acutuly theres a few hehe.
    with the disk brakes with some modification supra jza/ma70 rear brakes go on look in conversion's its all in there.
    there plenty of ratios 3.9:1 im pretty shaw you can get with the lsd youll just go buy aftermarket theres plenty out there.
    S.A
    The length doesnt matter that much as it will have to be cut down any how.
    Aftermarket LSD? ........ Any factory ones?
    Any difference in strength between the earlier ones (80's) and later ones (90's onwards) ?
    They do come with factory LSD's, im not sure what ratios they come in. But they are as rare as hens teeth... CVAP have them, but in limited ratio's...
    If its going in a cortina, surely there is a holden or ford option for you that would be easier, cheaper and posibly better. Or atleast better for your application...
    I just assume that a cortina is wider so there are more diffs available for ya...
    Jase
    EDIT: If length doesnt matter anyway, wouldnt a later model commodore or ford diff be cheaper, easier to come by, and already have disks?
    JZA023
    the mx83 cressida grande auto and the ma70 supra manual non turbo is a 3.9 LSD but its irs, and to swap the gearset and centre over into the hilux case and to have it set up will cost about $400.
    Hilux lsds are obviously the way to go if you can get over the fact they are 4.1 or lower....
    aftermarket lsds - theres farking heaps!
    ratios vary from 3.7 in a supra turbo manual to a 4.89 in a hilux diesel.
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    S.A
    yeah good point about the ford option etc etc.
    I just heard of the hilux strength and thought that mabe a good option.
    Id like to go with a banjo type for ease of change should something break.
    a ford 9 inch will cost you less im sorry to say...if you want lsd and discs...
    add another $400 to set up those rear brakes on the hilux diff.
    S.A
    yeah i know but 9 inch is way over kill + toooooooo heavy .
    Ford 9inch also has added advantage of banjo style!
    JZA023
    S.A
    If i went with a 9 inch , id atleast have to go with a alloy carrier to save some weight.
    I dont think my wallet likes this apporach.
    dude i hope you dont think hilux diffs are light??!! the 9" weighs at most 20-30kg more!
    S.A
    Nah i know they arent light But they are nowhere near as heavy as a 9 inch !
    Junior Member Backyard Mechanic TA22 1MZ's Avatar
    Hi mate
    I swapped a RN25-27 Hilux diff into my TA22 Celica. They are 1370mm hub face to hub face. I went with the shorted approach but was only able to shorten the axles a little because of the limited spline on the axles. Obviously if you wanted to respline them you could shorten as much as you want. I went with a AE86 rear caliper and rotor setup. There are plenty of other options out there including R31 Skyline and MA70 setups.
    Diffs are tuff as, weigh far less than a 9" and have plenty of ratios and centres available. LSD's are plentiful! There is a Toyota wrecker in SA that has a heap of these diffs which are becoming hard to find as they are the earlier shorter model.
    If you need anymore info let me know
    Hey dude, was looking at THIS and if mk1 and mk2 rear ends are the same or relatively similar, they say, if you can put up with a salisbury style diff, then the commodore borg warner is a good option... Easy to find, easy to get parts for etc... And already have disk rear end...
    Just another idea,
    Jase
    JZA023
    Quote Originally Posted by Smokey228
    Just another idea,
    Jase
    i think this is what jason on here runs in his yellorolla which runs 11's....so they arent weak by any means
  1. Hilux Diff question
    Last Post: 25-09-2007, 08:19 AM
  2. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 12:41 PM
  3. Current model Hilux diff observation.
    By MacroP in forum Tech and Conversions
    Last Post: 30-08-2006, 04:49 PM
