I have just swapped from a Mitsu diff to a Hiace. Hiace is g series as well but 1470mm wide. Drum brakes also but I imagine anything that would fit hilux housing would fit hiace as well. I am happy with the drums though.
I was going to go down the cressida 3.9 gears into a hiace/hilux housing but in the end found a 4.11 hilux centre (non lsd) and got that welded up. I had a thread and there were 2 others about fitting the IRS gears into the non IRS housings. You will have to take it to a diff shop that know what they are doing. What put me off is that one of the places that had already done it didn't seem to know very much about it. As I am no diff expert I thought it was easier to ge the 4.11's and be done with it.
I was also looking into the BW78's as they are cheap and as they say lots of quick VL's etc. However, I also like the banjo type diffs so that didn't help. Most ratios were very tall at around 3.23 or something like that. And apparently with these types of diffs you have to get a diff shop to swap the gears in them rather than just a whole pumpkin swap (unless you know how to set backlast etc. and I don't).
In summary, I would probably get a hiace housing if they are cheaper as you are getting shortened anyway. R31 disks and then redrill studs if you want 5 stud. You can get 3.7:1 LSD's out of newer hiluxes. See the toyman75's members ride thread for details. They aren't called G series anymore but they are 8".
HTH
Chris![]()
... 11's soon
dosn`t include surf`s)
