Results 1 to 10 of 10
Thread: R154 - who can tell me the name of this thing / a build plate so i can buy a new one?
    Default R154 - who can tell me the name of this thing / a build plate so i can buy a new one?
    this shaft is broken and i need a new one. What do you call this part? and good old toyota wont help me unless i have a vin number and all that shit. anything from a jza70/jza80 etc basically anything that came with a factory R154. any help would be appreciated.
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Default Re: R154 - who can tell me the name of this thing / a build plate so i can buy a new
    Surely with the photo they can look it up in the EPC? Call James at Castle Hill Toyota and tell him you want to email a pic. He's very helpful. If I had to guess I'd say Input Shaft cover?
    Hey man,
    JZA80 never came with R154's only the MA70/JZA70 turboes did. (and some other non supra cars).
    http://www.toyodiy.com/parts/p_J_199...LMQZ_3302.html
    Would seem to be this bit 33131-35031.
    Called Retainer, Bearing, Front.
    Junior Member Grease Monkey Maverick's Avatar
    N.S.W.
    How did you manage that?
    bought it as is, from a man named "shifty". it came from japan and it was on a crate so i can only imagine a dodgy forklift driver hit it some how.
    12.4 @ 110mph
    that bearing retainer is also found on local Toyotas such as Hilux v6 and Prado with R150/1 gearboxes
    Jealousy is a curse
    No doubt its also found on local Toyotas such as the MA70/71 turbo Supra...
    ok thanks guys. Will ring castle hill toyota. On another note i just got a chance to dummy fit my motor tonight and the shifter goes past the original shifter hole, can anyone tell me if you can convert a remote type shifter R154 to the non remote shifter type? would i need to change the rear housing? or just the top part?
    12.4 @ 110mph
    You should be able to have that welded back in if its too expensive.
    Yeah, you can convert them, but I don't think its as easy as unbolting and rebolting.
    Depends what car yours came from, all the remote shifters have different bolt patterns where it bolt to the box (rear housing).
    jzx90 i think
    i was thinking that too but if i welded the collar back on then the welds might not allow the throwout carrier to sit as far back as it originally did, and if i grind back the welds it would not be as strong as it originally was. Or do i worry too much?
    12.4 @ 110mph
  1. W5X Speedo Drive Comparision (Steel plate vs Alloy plate)
    Last Post: 12-08-2011, 07:58 PM
  2. Clutch for R154
    By millers in forum Tech and Conversions
    Last Post: 21-11-2008, 02:30 PM
