Yep is sure does work, cheap otpion for reliable EFI management.
Just curious, I was reading the the early 4age ecu's wire up nicely to the 2tge is this true?
Does it work well??
Originally Posted by http://www.northbaymotorsports.com/toyota18Rcelicaengine.htm
Well whatever, but Rex cant see it yielding 'good' results.
Surely the 2T would need the swapping of all sensors etc. to feed all the proper 4AGE signals to the ECU.
It also assumes both engines have identical VE characteristics.
IRHO, Good carbs, good tune and electronic ignition OR basic aftermarket programmable EFI would whallop it every time...
Rex Kelway Sucks - Fabrication thread
Rex Kelway - ABN: 41 267 379 001
Fabrication, Manifolds and CAMS spec Roll-cages in SA...
Well whatever, but Rex cant honestly see it yielding 'good' results.
Even then the tune cant be that good as the swap assumes both engines have identical VE characteristics.
Got a spare 4age ecu if you need one![]()
Hey honestly I just was curious, could be a cheap upgrade for the 2TG boys...Foamy whats it out of?
Came out of a AE82 corolla. I have no idea if it was a bigport or smallport....make an offer and it's yours!
Just curious whats the difference between the AE86 and mk1 MR2 4age ECU's (afm) vs. say just a ae92 4age ECU (map)?
I know they are both AFM not map but other than that, why are they so special??
