Results 1 to 13 of 13
Thread: narrowing st205 caliper possible?
    nuts Grease Monkey
    auckland
    Default narrowing st205 caliper possible?
    hey just wandering if anyone has stripped down an alloy 4pot st205 caliper and seen if it's at all possible (or done it) to skim the join faces so they can be fitted to thinner disks?
    -Mark
    E2 + E7 fan
    Default Re: narrowing st205 caliper possible?
    Quote Originally Posted by AE25 View Post
    What about getting spacer plates cut to sit behind the pads?
    My KE25 thread
    nuts Grease Monkey
    auckland
    wouldn't spacer plates cause it to squeel?
    i don't think a 315x32 (12.4") disk is going to fit under 15" rims. so something more suitable would be 275x25 which seems to be a common disk size. 7mm is quite a drop though. im not sure how the calipers are sealed together without splitting them apart.. whether or not trimming the mating faces will affect the fluid line.
    -Mark
    E2 + E7 fan
    Squeal, maybe it would but some anti-squeal compound on the back of it would probably stop that.
    What total disc height do you need for your setup?
    I'm fitting 280x30mm discs to my KE25 at the moment with R32 4 pot calipers and that fits under 15's with ease.
    My KE25 thread
    Tasmania
    205's run a 16" rim factory so if you are using the same diameter rotor (315mm) your going to be in struggle town with a 15" rim.
    1973 TA22
    nuts Grease Monkey
    auckland
    cheers guys
    disk size doesn't need to be overly huge considering the weight of the car and intended purpose.. is going into a ke25 also as a steet/weekend car with the occasional track/gymkhana/drag day. didn't want massive disk width to keep unsprung weight down. hence narrowing of calipers to fit thinner disk. 25-28mm absolute max width.
    im using ae86 struts. disk bolts to the back of hub and i'd like to keep it that way for best rwd wheel offset using 15" rims. so looking at getting custom centers made for a race style floating disk giving me better options for bolt on disk sizes. please tell me if im going wrong way about it. picked up these st205 bits recently so thought i'd do my best to make use of em.
    -Mark
    E2 + E7 fan
    Jul 2008
    Just split one in half and have a look.most likely one face will be flat and one face will have a recess around the fluid gallery to take an o ring.In which case you should be able to mill some off the flat side.
    Al.
    New Zealand
    Hey Mark, may be interested in some sort of deal on those calipers. I've got a set of MR2 calipers and rotors stashed away somewhere. The 205 stuff may be a better option than my Altezza calipers depending on mounts etc and will fit my discs (298x32mm I think).
    Callum
    nuts Grease Monkey
    auckland
    i'll keep ya in mind for me, its these or wilwood dynalites... so um yeah these are in my possession already.
    mr2 or altezza calipers aren't alloy are they?
    i have st185 calipers here which i'd imagine pretty similar to mr2 yah?
    -Mark
    E2 + E7 fan
    Aug 2008
    Tasmania
    AL510 is quite correct, one side is flat the other is recessed for the oring, ive got a 205 caliper at home that is broken in two if you want any pics or info!
    1990 AUS ST185 Gt4 - The Money Pit - SOLD
    1977 RA28 Celica - 1UZ power in the making!
    1991 UZZ30 Soarer - SOLD
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Mark,
    you may want to read this before doing any caliper mods.
    http://www.infrastructure.gov.au/roa...s_3Feb2006.pdf
    nuts Grease Monkey
    auckland
    cheers thino. are you able to see if there would be any structural weaking of the caliper if it were to be thinned down at the mating faces? the oring groove can always be remachined back in
    auto351 thanks for the link. seems like some sensible rules there. although auckland is not a state of australia so different rules apply over here. but cheers
    -Mark
    E2 + E7 fan
    By The Witzl in forum FAQ
  2. Nissan 4 spot callipers
    By cambelt in forum Tech and Conversions
    Last Post: 30-01-2009, 09:21 AM
  3. How to :Creating caliper mounts
    Last Post: 10-11-2007, 07:08 PM
  4. putting a spacer in a caliper to allow a thicker disc. wise?
    Last Post: 13-03-2006, 02:40 PM
