Results 46 to 49 of 49
Thread: Generic *budget* low boost turbo build
  1. #46
    Junior Member Grease Monkey Maverick's Avatar
    N.S.W.
    Default Re: Generic *budget* low boost turbo build
    Buy a g13b for a $300, put a turbo chip in the gti ecu and be done with it... if you sold your g16b motor you could prob do it for a few hundred bucks...
  2. #47
    G13B=too peaky for a 4wd Also G16 and G13 are not *directly* interchangable, and G13B is still quite a pricey unit, especially compared to a G16. Also, G13B will need an angle drive kit for the dizzy, and at $600 each, they're not cheap...
    -RM
  3. #48
    Jul 2009
    Quote Originally Posted by mullett View Post
    *it's a G16B motor in a Vitara*
    4AGZE tiem?!
    http://www.youtube.com/watch?v=Cd4eIYWQOQ4
    Sierra, Vitara, they are nearly the same
  4. #49
    Haha, if only. Real problem is Sierras run a seperate transfer case, so you can easily put pretty much any engine/box in them if you can shoehorn it in. Vitara runs an integrated transfer case, so you either have to use the factory box, or do a lot of custom work to make a sierra transfer case fit (and then swap the diff centres for Sierra ones, because Vitara ratios are very high), which is too much effort
    -RM
  1. How to Gain Extra Boost from Ct-26 Turbo
    By Robert Smithers in forum Tech and Conversions
    Last Post: 19-09-2006, 07:00 PM
  2. Boost controller on 1G twin turbo
    By THREAT in forum Tech and Conversions
    Last Post: 18-09-2006, 06:49 PM
  3. Boost Leak Tester
