Results 1 to 8 of 8
Thread: engine mounts
    Feb 2010
    Default engine mounts
    hey swapping a 1jzgte into my toyota cresta which has a blown 1ggte i it now =[
    im just wondering if i can use the same mounts instead of goin custom mounts?
    Default Re: engine mounts
    You can buy the jzx81 mounts from toyota at a very reasonable price.
    Oct 2009
    believe the price is about $120 posted
    Junior Member Domestic Engineer 1jz68u's Avatar
    i believe you will also need the series 2 xmember. but i could be wrong..
    Glenn
    Current Ride http://www.toymods.net/forums/showthread.php?t=41123
    Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
    Quote Originally Posted by NME308 View Post
    You do of course realize forgiveness is easier to gain than permission right???
    Cheers, Jason
    HEAPS easier to source a jzx81 frontcut to start with.
    that way you get the correct mounts, crossmember, sump, brackets, AC lines/condensor, PS lines/resivour, accel cable, heater lines, heater tap, radiator, loom etc etc etc.
    Feb 2010
    Quote Originally Posted by JP View Post
    place im buying from rekons everythin is there loom etc just i dnt wanna pay them to 2.5g labour to put in
    Low rep 1st year Apprentice
    Feb 2010
    vic
    you may find this link economical..
    http://www.car-stuff.com/
    If it's not a jzx81 frontcut there will not be all the bits there you need, and you will either have to get custom items fabricated or go sourcing the parts individually. I've done three GX to JX conversions, two were with jzx81 frontcuts which were very easy, the third was starting with an engine/box/loom which I then had to source crossmember, mounts, accel cable, custom PS lines, custom AC lines etc etc etc.
  1. welding new engine mounts - opinions please
    Last Post: 05-06-2008, 01:23 AM
  2. MA70 --> JZA70 Conversion
