Do you have a multimeter or a voltmeter? you need o check to see if you are getting power to the starter solenoid,Several other questions need answering , does it have an imobilser? is the battery fully charged?What sort of car is it?
Hey guys ok yes im new but i got a real issue on my hands with this soarer. I bought this car as a project. Ok now the owner who had it said he started it on 3 cils about 3 months ago if im correct. Now i get this car, tells me a need a new dizzy so i got one, put it in exactly how its suppose to... Turn the key.
NOTHING.... no noise, no turn over....
Tried hitting the starter motor, nothing. Im about to fully lose it soon so if someone can seriously tell me this issue or help me asap, i would be so grateful....
Cheers Dave
1977 RA28
1972 TA22
1984 Supra
certainly sounds like the starter motor to me!
firstly I would test that the starter has 12 volts across the terminals - obviously no power would cause some insufficiencies! - then assuming there is power, try shorting the starter motor from the positive terminal to the starter solenoid to make sure there isn't a wiring issue, and that the starter works and is connected to the power!
that may help you find the problem.
Do the instrument cluster lights come on?, charge, oil etc etc?,
For a starter not even to make a clicking noise, the battery is disconnected or the cable from the battery is disconnected or the ignition wire to the starter ( the smallest one connected to the starter) as others have said.
Stupid question, are the battery terminals connected and the earth cable
So you can't even hear the injectors ticking right?
If the motor isnt turning the injectors wont tick.
Have you disconnected or played around with any wiring in the solenoid/fuse box's in the engine bay.
Ok if i could do this stuff i would but i have no tool and the proper knowledge to try this as i might do more damage.
BeRad- yes all the cluster lights come on...
Are you Sketra from TOCAU? If so, oh dear...
