Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: 4age to 4agze Daily
    Default Re: 4age to 4agze Daily
    You need to learn to read a dyno chart... The solid line is the power, dashed is the AFR which you see is in the low 11's.
    Stock wiring has #10 going to injector 3&4, #20 goes to injector 1&2
    Sep 2009
    I've actually never had a car dyno'd so you are correct i wouldn't know.
    thanks for that conformation on those wires.
    Gearwhore. Backyard Mechanic
    Oct 2008
    Quote Originally Posted by TERRA Operative View Post
    Check out my dyno chart above, the air fuel is pretty constant, no sudden drops etc.
    Interesting that it still happens with turbo, I never knew that. IIRC, it's been found that the knock sensor is maxing out (like screaming into a microphone), so I wonder what is causing it? Too bad we don't have a brand new crate motor to see how it acts....
    Might not be related, but I have heard stories of bad harmonics caused by the crank around that RPM on a few engines. Possibly it or some other rotating component is ever so slightly misbalanced from factory?
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Chiba
    Well, pending the supply of the front bearings (I got the seals and rear bearings, they're easy to get), I'll be fully rebuilding my SC14 soon, so we can see what the dyno says after then. Will probably be the same, but it'll be interesting to see what happens with a fresh supercharger.
    Jan 2007
    queensland
    a mate of mine runs my old AE92 GZE ecu/whole setup on his NA bigport (going to turbo but hasn't yet) he has been running NA for a few yeard now.. and just left the knock sensor unplugged... it was on a bigport anyway we tapped a boss in the block around the same location to put the knock sensor on but it would run like shit with it connected..
    so we just left it unplugged.. set base timing to a conservitave 12 deg BTDC.. he has been reliably circut racing it ever since..
    also i never had an issue with my AE92 map GZE in my AE86... here is my dyno chart.. and a video.. definitly no power drop after 5500... why isnt it a universal problem? seems like it happens to most.. but not all GZE's..
    if you are running the stock interwarmer i would suggest you don't even try running without a knock sensor..
    http://www.youtube.com/watch?v=U9NWmf4RNNQ
    and this is my bro in laws 86 that has been running the gze ecu/injectors/coilpacks etc etc for a few years with no problems without the knock sensor connected..
    Jan 2007
    queensland
    only real reason i suggest not running it is due to your running stock boost.. with no intention or raising it.. the GZE being quite tough... if you pull a tiny bit of base timing out of it, i can't see any real issue.. providing that you have sufficiant intercooling eg.. anything but the stock cooler..
  1. NA 3TC or 4AGE for Daily Driving
    By brucey in forum Tech and Conversions
    Last Post: 16-08-2009, 01:56 PM
