Results 16 to 21 of 21
Thread: Calling all 1JZ guru's
    Default Re: Calling all 1JZ guru's
    If there is voltage to the igniter, is it likely its a bung igniter?
    Test the inputs and outputs of the ignitor. 5V square wave inputs, ground switching outputs. A missing IGF signal will shut the engine down so it needs to be checked also. It's a switching ground to the ecu also IIRC.
    Did this get sorted? what was it?
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    busted coil bud... she runs now... lil rough due to lac of exhaust but she runs!
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    cool
    1234567890
    Mar 2009
    Auckland
    hey guys 2 questions. what does the vb wire connect to and do 2jz vvti waste spark coils have built in ignition suppressors?
  1. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 08:13 PM
  2. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 05:04 PM
  3. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  4. 1jz and Haltech e6k
    Last Post: 10-10-2006, 05:25 AM
