Results 1 to 15 of 18
Thread: Vac switch? I want to turn stuff on.
    Chiba
    Default Vac switch? I want to turn stuff on.
    Just looking for an easy way to switch a relay at between 8" and 0" vacuum and keep it on through to positive pressure. Any ideas? Googling only seems to reveal industrial switchgear and the like........
    Default Re: Vac switch? I want to turn stuff on.
    Do you have a MAP sensor that you can get a voltage signal from?
    Chiba
    On my engine yea, but I'm looking for something cheap that I can use on any car.
    what ECU do you intent running? anything half decent will have a programmable output (e.g. when rpm>0 and MAP>80kpa, port X earths).
    Chiba
    It's for a stand alone application. The sensor just has to switch on a relay as the manifold pressure rises above about 8" to 0" of vac. Totally independent of anything else.
    Something like this is what I'd use, but it's only applicable to engines that have a variable voltage MAP sensor http://autospeed.com.au/cms/A_110548/article.html
    Chiba
    I could probably use that with a MAP sensor. It needs to work on AFM engines etc, so an independent MAP sensor is required.
    I'll have a look into it.
    Jaycar have a kit that looks to do what you want...
    http://www.jaycar.com.au/productView.asp?ID=KC5377
    But then again a conparator and a few resistors could do it too (and for cheaper)
    LM311 = $1.95... http://www.jaycar.com.au/productView.asp?ID=ZL3311
    Resistors / Pot = cheap
    http://home.cogeco.ca/~rpaisley4/Comparators.html
    I.e.
    Wilbo's JZA80
    Wilbo's JZZ12
    Chiba
    That looks like it'll do what I want. I might experiment with that.
    Thanks.
    Wilbo's JZA80
    Wilbo's JZZ12
    If you go down the Comparator route, you'll need a 5V+ Regulator to provide the 5V+ Ref segnal to the MAP sensor and the circuit Wilbo's listed.
    Could also acquire from +5V from the ECU... (i.e. TPS)
    Wilbo's JZA80
    Wilbo's JZZ12
    Gearwhore. Backyard Mechanic
    Oct 2008
    5V regulator can be made for a few bucks, no point in chopping into ECU loom.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Chiba
    Yea. This could be installed on carburettered cars, so a regulator is no big deal to add in.
    Does anyone know of any good cheapish sources of MAP style sensors? Not the wrecker, as I can't guarantee supply (I'll be making a few of these things) and RS Components wants about $50 a pop for just the sensor module. The range only has to go to about 5psi, but it has to withstand at least psi.
    Apr 2007
    wilcannia NSW
    carburettored early magnas and later sigmas had an adjustable vacuum switch which turned on a light at low vacuum. it could be used to switch on a relay. they fit in your pocket at the wreckers
  1. Ignition Switch
    By rj_darlow in forum Tech and Conversions
    Last Post: 20-10-2006, 12:48 PM
  2. TPS Idle Switch
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 19-03-2006, 06:44 PM
