Results 16 to 24 of 24
Thread: Lift Pumps - what to use cheaply?
    wa
    Default Re: Lift Pumps - what to use cheaply?
    They dont last very long and are noisey.
    What about a vl coomodore lift pump as they run an external pump
    Quote Originally Posted by JustCallMeOrlando View Post
    What's wrong with using the Magna fuel pump if it works well enough? Should flow plenty if it's just filling the surge tank and not having to fight
    Sorry, meant to clarify. I meant using it in tank as is, rather than trying to make it external.
    Any reason you can't do this?
    I'd be looking at doing it that way.
    Wilbo's JZA80
    Wilbo's JZZ12
    Its not a ticking noise. Its more of a rattle.
    I.e. Like a slide hammer going a million miles an hour. (Slight exageration but its louder than my engine even though its rubber mounted)
    i agree with the other doods, if the magna fuel pump can flow enough fuel for the engine id leave it as is. (assuming the fuel return goes to the surge tank also)
    Gearwhore. Backyard Mechanic
    Oct 2008
    Just get a VL pump, cheap as chips and really common.
    my problem is I can't be fucked fooling around to try and get the magna fuel pump to be 'in tank'.
    It's a case of - do I spend money getting the thing 'in tank' or do I simply spend roughly the same amount for an out of tank pump?
    Thinking maybe VL is the way to go now. Or VN v8 like Ian said
    Facebook | LinkedIn
    oh sorry dood. i misunderstood.
    I thought you meant the magna pump was already mounted in the tank.
    i'd just get an external pump.
    That's cool mate.
    I got my eyes on a VL pump right now.
    For under $50. :-)
    Facebook | LinkedIn
    Feb 2010
    Talking Re: Lift Pumps - what to use cheaply?
    Vl pump is the way to go, cheap as chips, picked one up from a wreckers for $15 bucks
    and just for reference there is no difference between a vl turbo pump or a normal vl pump, just a blue stripe and price tag who ever new racing stripes on a fuel pump made it better lol
    Boost Me, Then Double Clutch Me, Till I Can Get My...Loss Of Traction
    no backyard Domestic Engineer japlish's Avatar
    vl external pumps are no good as they also need an internal pump to feed it.
    fuelmiser part number fpe-135 is a good choice from the datsun 720's and mazda capella's as they are an external lift pump to suit carby's but will be fine for a lift pump.
  1. Supply flow needed for twin EFI pumps
    Last Post: 27-10-2006, 04:35 AM
  2. which lift pump? ... & spark plugs for 1ggze?
    By bexi in forum Tech and Conversions
    Last Post: 15-08-2006, 05:14 PM
  3. Guide: How to build a K series motor
    By oldcorollas in forum FAQ
    Last Post: 26-09-2005, 07:51 PM
