Results 1 to 15 of 24
Thread: Lift Pumps - what to use cheaply?
    Default Lift Pumps - what to use cheaply?
    So I have a magna fuel pump, but it's in tank and I suspect it won't go too well out of the tank.
    What can i use for a lift pump that's cheap? I don't really want to shell out big bucks for something that's pretty low rent anyway.
    Facebook | LinkedIn
    Default Re: Lift Pumps - what to use cheaply?
    What's wrong with using the Magna fuel pump if it works well enough? Should flow plenty if it's just filling the surge tank and not having to fight rail pressure.
    Sorry, meant to clarify. I meant using it in tank as is, rather than trying to make it external.
    wa
    I have a carter black cost about 130 dollars and flows a heap.
    Could possibly look at something like a holley blue black or red
    Or a facet pump or two
    Pretty sure the magnafuel pump wont draw fuel from the tank unless its gravity fed
    Eltham vic
    hi strad
    we used a vn v8 pump in the club car , it works quite well
    Ebay have some cheap external lift pumps.
    Junior Member Grease Monkey seamonsta's Avatar
    May 2007
    Hills Area Sydney
    Can't go past a genuine Walbro..bro, for in tank.
    I am using a Pierburg lift pump. Cost $200 in Mackay retail money, but flows a bucketload and isn't terribly noisy. You should be able to find it cheaper.
    Also running a Pierburg high pressure that I got for $70 on flea-bay secondhand and it runs a treat. As for the cheap flea-bay pumps, if they are anything like my cheap flea-bay fuel pressure regulator, I wouldn't waste the money.
    it looks like people spend as much money on the lift pump as they do on the high pressure one?
    Facebook | LinkedIn
    vic
    Cant beat a peirburg , I can help with new at $150
    Dave
    Yikes, that's some serious money for a lift pump.
    And here I was thinking I could get away with being a tight arse. :-)
    Facebook | LinkedIn
    Tasmania
    Go to Repco and buy a facet pump or whatever they call them cost around $50.Cheap and easy and works well.
    Cheers Brett.
    vic
    Go Facet if you want a very anoying tick tick and short lifespan , they are a very sub standard pump.
    Dave
    Facet pump drives me farking nuts. Getting rid of mine coz of that.
    so facet is annoying is it?
    Is it just the ticking?
    Facebook | LinkedIn
  1. Supply flow needed for twin EFI pumps
    Last Post: 27-10-2006, 05:35 AM
  2. which lift pump? ... & spark plugs for 1ggze?
    By bexi in forum Tech and Conversions
    Last Post: 15-08-2006, 06:14 PM
  3. Guide: How to build a K series motor
    By oldcorollas in forum FAQ
    Last Post: 26-09-2005, 08:51 PM
