Results 16 to 18 of 18
Thread: front chassie rail tie bar (how to fab) for AE86 or similar
    Nov 2009
    Tas
    Default Re: front chassie rail tie bar (how to fab) for AE86 or similar
    the one picture above, with the yellow rotisery...
    i just looked a bit closer, i dont think thats a replacement tie bar rather just a piece of angle welded to the leading and lower sides of it... is that what it looks like ?
    Owner built, tuned and driven. 420kw 9000rpm 3sGTE AE86 Levin
    yup - they've just attached the length of angle to it. effectively double-skinning it.
    don't bolt it - just weld it all together.
    Dont weld on the plates that the tie-rod and roll-bar attach to unless your front roll-bar is a hollow-rod thing with adjustable blades.
    Nov 2009
    Tas
    the castor rod anchor plates that house the sway bar mounts will be bolted to the car.. but ill be welding roll cage tube between the anchor plates and the engine x member to turn it into a 1 piece subframe.. this should spread the load around the whole front end of the car and decrease flex significantly
  1. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 10:54 AM
  2. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  3. MA61 KYB Front Shocks Question "The Shocks Thread"
    Last Post: 01-02-2006, 10:58 PM
  4. Replies: 4
    Last Post: 08-09-2005, 01:17 PM
