Results 1 to 15 of 28
Thread: Which R154 for JZA80?
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    Default Which R154 for JZA80?
    Hey Guys,
    I am going to be helping a mate put a 2JZGTE in his SZ Supra.
    We are looking at putting in a R154, but are unsure what gearbox we need.
    Some of the info I have found says that I need a Soarer JZZ30 box, but I dont know if this is supposed to be the remote shifter type, or the one that is very similar to the JZA70 box.
    We are obviously trying to get all the right parts up front, so if anyone has done a similar conversion and could let us know, that would be great.
    Thanks,
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
    Default Re: Which R154 for JZA80?
    JZZ30 is the ideal one. The Soarer and Supra chassis are pretty much identical. Good luck finding one though
    Feb 2007
    Is there much stuffing around getting the JZA70 one in?
    Shifter position, bellhousing a different shape, etc?
    If you intend on using all the other JZA70 manual conversiopn parts then yes there are quite a few differences judging by this thread on a JZA70 R154 manual conversion into a JZZ30 Soarer
    http://soarercentral.com/sc-forum/me...78/278283.html
    Feb 2007
    The car is already a manual, and Ive heard that you dont need a remote shifter for the JZA80 R154.
    Am trying to confirm all of this.
    Herus
    You definitely need the remote shifter if you want it to be anywhere near the factory location; the JZA80 boxes (V160 and W58) both have a remote shifter.
    A JZA70 box will bolt up OK but you'll probably have to butcher the tunnel a bit.
    from good ol yahoo
    JZZ30
    JZA70
    no JZA80 R154 pics atm, but a V160
    Quote Originally Posted by Herus View Post
    There is no JZA80 R154.
    JZX90/JZX100/JZX110/JZZ30 are all the R154's that will be suitable
    The JZA70 boxes will need a custom shifter-extension to get the shifter far enough back, so it's not ideal, but still can be made to work.
    Feb 2007
    Orlando, I mean to convert... I know there isnt one factory..
    Thanks for the pics there oc, Definately looks like it needs to be remote shifter..
    Thats going to be fun to find!
    Herus
    To further complicate things, that JZZ30 pic is of a post '96 remote shifter box, JZZ30 ones prior to this *looked* the same as the JZA70 one but wernt
    Junior Member Backyard Mechanic manny's Avatar
    As Sciflyer noted, there were two versions of the R154 fitted to the JZZ30
    Early 91-93 model with rear most in housing shifter position
    note the JZZ30 goose neck shifter - a JZA70 shifter comes out under the radio in a JZZ30 otherwise
    Later 93-00 model with remote shifter
    There are two distinct transmission tunnel cutouts with the JZZ30 to suit either version, so it will come down to what position the JZA80 tunnel cutout is closest to.
    Another A70 Supra R154 example
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    thanks for clarifications.. i was confused thinking sellers were confused when finding JZZ30 boxes without remote shifters
    Feb 2007
    So we can use any JZZ30 box, or even a JZA70 box, if we can find a gooseneck shifter?
    Does the JZZ30 remote shifter gear bolt straight onto a JZA70 box?
    I know Wilbo covered this in another thread, but he had JZX100 remote shifter vs JZA70.
    Herus
    I suggest getting whatever R154 is around...and R154 that can take the JZA80 W58 gearbox mount would be a preference (Not all R154 can take this gbox mount!)
    If you get a remote JZZ30, then that's easiest, but otherwise I'd just do the below... stolen from a google image search (HOWEVER, I'd get the angle correct! Unlike the pic)...
    You can do this with the parts you have on a non-remote box, and it shouldn't take that long or cost much if you can't do it your self...
    If I was doing it again, I'd extend my non-remote shifter
    Wilbo's JZA80
    Wilbo's JZZ12
  1. r154 shifting experiences
    Last Post: 24-11-2009, 10:47 PM
  2. R154 Selector Forks.
    By Turbomini in forum Tech and Conversions
    Last Post: 17-07-2009, 05:30 PM
  3. R154? Good or no good?
    By TTV8RA23 in forum Tech and Conversions
    Last Post: 12-02-2008, 10:18 AM
  4. R154 Rebuild Questions
    By delazy in forum Tech and Conversions
    Last Post: 22-08-2007, 07:14 PM
