Results 1 to 6 of 6
Thread: rebuilt smallport 4age with pinging issues
    Jul 2007
    VICTORIA
    Default rebuilt smallport 4age with pinging issues
    Hi guys,
    I've recently completed a rebuild of a Smallport 4age. All is good with the engine except i've had to retard the base timing back to b/w 0 and 5 degrees to stop detonation.
    Just to give you some background
    Stock Bigport cams
    Compression ratio is ~12-12.2:1
    running on a stock bigport ecu with no error codes.
    the cam timing is correct.
    running BP ultimate with nulon octane booster to try and help.
    currently setting up a water injection system to prevent knock.
    Now i'm running the stock ecu only for the short term to run in the engine before running bigger cams and aftermarket ECU.
    I feel the issue is too much compression with these cam in the bottom end as it can detonate when free revved from idle in neutral when running 10 degrees base.
    I need some thoughts, would altering the cam timing to bleed off some compression in the low end to enable the timing to be increased back to stock and then use the water injection under higher loads.
    thanks in advance to any help.
    oregon
    Default Re: rebuilt smallport 4age with pinging issues
    Quote Originally Posted by webby View Post
    Stock Bigport cams
    WAAAAY too much DCR!
    To run 12 to 1 compression you need to run a longer duration camshaft
    Jul 2007
    VICTORIA
    Thats what i've now realised.
    whats a good DCR to be running on a 16V?
    from using a online calculator its currently 10.9:1 would say 9.6:1 be reasonable
    Gearwhore. Backyard Mechanic
    Oct 2008
    CR needs to match everything else. First step - get a decent cam, then get an aftermarket ECU.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Stock compression ratio is 10.3:1 from memory
    Sep 2009
    Quote Originally Posted by the_random_hero View Post
    Please do this.
    then come back with your insane power from that CR. aftermarket ECU and decent cams are a must, the power would be quite good i would imagine.
  1. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
