Results 1 to 15 of 16
Thread: suitable master cyl
    Default suitable master cyl
    Looking at doing the hilux peugeot brake upgrade, I have found this on EGAY USA and cant get any defffinative info on it. IS it the MA70 one or not?.
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Default Re: suitable master cyl
    looks like the one i just got. will try and post a pic tomorrow
    Now - RA23-WRX
    It does look like the MA70 one. (Reservoir is a little different, but much of a muchness)
    victroia
    dont know if it will fit in a celica, but i run a VN 1" master in my ke55 with same brakes, works great, they fit the aus built rolla boosters
    not sure if this will help but it may
    Thanks it does look OK, I will try and find out more about it.
    Thanks
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Isn't the KE55 a 2-bolt master cylinder, but the 28 needs a 4 bolt unit?
    seeyuzz
    river
    Correct River.. though I am not sure what the PBR booster runs in the later KE55s. Being PBR is probably why you can run a Commodore one on that booster. Wont work on a celica though.
    Took a photo of the one I bought for my car. The stud pattern is right. It has three outlets (two at the front)though which means I guess I have to block one off? Will ask that in the celica thread after doing a search to see if there is an answer.
    Also not being a person who understands electrics.. other than when the smoke gets out thats bad... I would like to know how you wire up the two wire brake fluid level warning from the supra to the one wire/two plugs in parallel celica wiring loom.
    Now - RA23-WRX
    Two wire? For the one resovoir?
    Anyway.... as you are in Victoria, you may want to contact Hoppers Stoppers and purchase their master cylinder. They have a 1-inch bore MC that bolts to the RA23/28 booster and connects up the lines as well. When dealing with brakes I find it best to go for something new.
    seeyuzz
    river
    yeah i guess power and earth... but who knows. you can see the lead hanging out of the reservoir lid in the photo.
    now you tell me about the hoppers stoppers m/c
    i was looking for new as i think the same way, but ended up with second hand when the couple of brake places i spoke to were of no use..
    oh well you live and learn
    Now - RA23-WRX
    I think it's $220.
    I decided to get one, along with the vented disk brakes upgrade for Trini. May as well get the whole lot done in one hit, and use new components.
    seeyuzz
    river
    http://www.cygnusx1.net/Supra/Librar...l.aspx?S=D&P=7
    One wire to constant earth, the other is the switched earth.
    So... you should be able to join those 2 wires together? And it will work for an RA28?
    seeyuzz
    river
    Nah OMR.
    Connect one wire to an earth. Connect the other wire to the original celica wire.
    Which colour wire goes where?
    seeyuzz
    river
    Well if its the same as the wiring diagram then White-Black to earth and the other wire to celica wiring.
  1. TA22 Brake Master Cylinder options...
    Last Post: 09-04-2022, 05:31 PM
  2. MR2 Brake master and proportioning upgrade
    By Joshstix in forum Tech and Conversions
    Last Post: 27-02-2008, 02:57 PM
  3. JZA70 Master Cylinder in RA23 - Advice Please
    By fuzz! in forum Tech and Conversions
    Last Post: 26-02-2006, 04:08 PM
