Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
Thread: using a solid state relay on a twin outlet coil.
    Default Re: using a solid state relay on a twin outlet coil.
    hmm link doesnt work because the shortened part is staying shortened if you know what I mean
    Quote Originally Posted by Sam_Q View Post
    well I have a sneaky way of getting a signal on when to fire which I prefer not to share.
    Are you King Mick?
    seeyuzz
    river
    ok can someone translate that for me
    google says it is also linked in this thread http://www.toymods.net/forums/showthread.php?t=51149
    Nov 2009
    Tas
    wouldnt it be easier to relocate the dizzy to drive off the front of the motor like ive seen the japs do a lot of the time..
    i no you can get an electronic sequence switch but im not sure how it would know when to switch which channel.. as in it wouldnt be getting a tdc 1 reference
    Owner built, tuned and driven. 420kw 9000rpm 3sGTE AE86 Levin
    Quote Originally Posted by s14seriesII View Post
    basically no, I have done it and there are some machining issues with it
    For IGf this thread may help.
    http://www.toymods.net/forums/showthread.php?t=36483
    Given what you have said I can only assume that you want to 'gate' off the injector pulse signal....
    Wilbo's JZA80
    Wilbo's JZZ12
  8. #38
    awesome thanks
  9. #39
    Forum Sponsor Grease Monkey
    I did build and had working in individual sections what your trying to do a few years ago in anticipation of my 3sgte having spark issues as I wound the boost up, but I never put it on the car as it never ran into ignition dramas with the dizzy..
    The only way I can see it working properly involves a far bit of electronics, which I can probably help with if a number of people would need it.
    If you are planning on using the injector pulse to sync up the coils keep in mind it may become unusable at 100% injector duty cycle, during decell cutoff down hills, during cranking and transient throttle when most ecus group fire. The only decent sync pulse I know of comes from the CAS and being reluctor will need some electronics to get the signal to a reliable trigger.
    Commercial style ignitors would be your best bet. They are basically just a transistor which is ok by itself (ie RB30's use just a transistor) but proper ignitors or ignition drivers have other bits added like current limiting and are designed to handle the spike at turn off better which can't just be suppressed using a diode as its this spike which is induced into the secondary winding of the coil to actually make the high voltage for the spark plug
  10. #40
    Sounds like a project that needs a really small microcontroller
    Once you pickup the sequence as long as you keep track of the spark and don't miss a pulse then the injector signal is just a backup
    My thoughts.
    Wilbo's JZA80
    Wilbo's JZZ12
  1. Which twin coils for 3T GTE ?
    Last Post: 26-07-2006, 10:43 PM
  2. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 12:29 AM
  3. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 06:52 PM
  4. Where to buy twin coil packs?
    Last Post: 17-12-2005, 05:17 AM
