Megasquirt has done that from the very start. it seems the intuitive way to do it, and i don't know why others did not do it before.
it does mean that you can just set say, WOT at 90-100% VE (100%VE is still an arbitrary number), and then work your way down with MAP/load.. and then tune from there.. also means you can use VE map estimators for different cam/engine combos.
it makes it really easy to swap injectors and injection settings, since the calculation from injector size to VE is done automatically (by calculating 100%VE pulse width), and then you can easily swap from say.. 1 injection event per cycle, to 2, or to alternating injection events etc, and still use almost exactly the same VE map.
it also makes it veyr easy to apply enrichments (or enleanments?) as a % rather than a ms pulse etc...
it makes it really easy to transfer between motors with different injector setups, and different turbo setups (since things tend to even out above 1atm).
