Results 16 to 18 of 18
Thread: ECU Tuning by Volumetric Efficiency
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default Re: ECU Tuning by Volumetric Efficiency
    sadly no option to convert my old injection time map
    car runs with the new haltech... I am keen to try a VE tune though.
    I will use the VE map from a 2JZ single turbo
    I will add my injector size, engine size, injector deadtime and go from there.
    Then I am assuming I correct the VE values until there is no difference between the target AFR map and the actual AFR displayed on the wideband.
    I am assuming the VE table should be pretty close to start with?
    Given VE is a function of theoretical flow vs actual flow, could I use VE values from another ECU, but for a 7MGTE? Mine is standard internally...
    Anyone have a VE map for a 7MGTE?
    Jul 2007
    the VE values are an estimate that the ecu makes, because there will be small changes from one motor to another. fuel pressure, inlet and exhaust manifold designs etc. But yes basically you adjust the VE value up or down till it matches your target AFR. Your new ECU should have an auto-tune feature in it which will help speed up the process as well, as you can then tune the map in large blocks. IE, autotune brings a certain cell down to 64% VE from say 80% that was arbitrarily entered at firsr, you then select a whole block around that cell and adjust them all to 64% VE. When the ecu next goes through these cells it will not need to adjust as much/will converge to the correct values more quickly.
    It's kinda hard to explain, but if you watch someone do it you will see it is really simple.
    makes sense to me! thanks mate.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 08:10 AM
  2. Volumetric efficiency for a 7MGTE?
    Last Post: 13-07-2007, 03:47 PM
  3. **bad info** 4agze Ecu
    By progkamol in forum Tech and Conversions
    Last Post: 26-07-2006, 05:38 PM
  4. ECU Tuning...?
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 29-05-2006, 05:47 PM
  5. Replies: 5
    Last Post: 13-02-2006, 10:34 PM
