Results 1 to 8 of 8
Thread: 9 inch diff info
    Jul 2008
    Default 9 inch diff info
    Hi guys, I just bought the vk commodore off the classified section with the 1uz and r154 in it.It is going to be used as a track car and currently has a 3.08 diff in it.I would like to lower the ratio some and have a couple of sets of 9" gears, a centre and a 28 spline full spool.
    What i would like to know is are the 28 spline salisbury axles the same spline as the 28 spline 9" spool.
    If this is the case it would make for an easy and cheap conversion.
    I know this is a toyota forum but im sure some of you learned people have mucked about with this stuff in the past.
    Cheers, Al.
    Tasmania
    Default Re: 9 inch diff info
    If the Commy has still got the factory Borgy diff then the 9" gears and axles will not go anywhere near fitting as they are near enough twice the size of the Coommy's.
    Easiest solution would be get a 9" diff housing to suit Commy.
    Cheers Brett.
    Jul 2008
    yeah, i know the diff is different i want to know if i can weld a 9 inch housing centre section between the commodore axle tubes and use the commodore axles in the 9 inch centre.if that makes sense?
    Jun 2006
    Yep, I think he is aware of that, What he wants to know, is, Are the axles the same IE will a BW axle fit into a 9' centre.
    Jul 2008
    Quote Originally Posted by wa5 View Post
    that is exactly what i want to know but the vk diff is the large salisbury diff, like a kingswood, apparantly they changed to borgies in series2 vk and vl.
    Cheers, Al.
    Jan 2008
    queensland
    wont a 9 inch be overkill for a 1uz really besides being a mile to heavy
    why not say a v8 vl diff with discs brakes and lsd (or spool if that is your thing) with six cylinder skyline gears 4.11:1 and 3.89:1 or falcon 3.45:1 and 3.23:1 gearsets.
    surely this would be adequate and easier.
    and not overengineered .
    just my two cents
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Jul 2008
    Thanks for your comments Neil,you are right that the vl stuff would be a lot lighter it was just an idea as i already had the 9 inch stuff laying around.
    I have a couple of t25 sr20 turbos going on as well so should make close to 350 hp at the wheels. Do you think the vl diff would be up to that?
    Cheers, Al.
    wa
    Vl diff will be up for 350hp at the wheels no trouble.
    My brother run about 450rwhp for about 5 years with his.
    The only advantage would be ratio choices
  1. Blown Cressida Diff
    By V8Cressida in forum Tech and Conversions
    Last Post: 07-05-2017, 12:08 PM
  2. Replies: 5
    Last Post: 15-12-2008, 08:40 PM
  3. Hilux Diff question
    Last Post: 25-09-2007, 08:19 AM
  4. RT142 Borg warner to R31 Diff (28 spline) conversion
    By Mickp in forum Tech and Conversions
    Last Post: 17-07-2007, 01:40 PM
  5. diff problems
    By Born-Enthusiast in forum Tech and Conversions
    Last Post: 24-06-2007, 10:38 PM
