Results 16 to 21 of 21
Thread: massive over filled engine oil
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: massive over filled engine oil
    True, I guess it's easily lost in the interpretation as I read it one way way and you/others another - only HAVABEER would really know what's going on.
    Quote Originally Posted by oldcorollas View Post
    O2 sensor is only for cruise really.. on throttle it has no effect..
    I know SFA about a 5s-fe so I'm not going to argue either way, but on the 1JZ, 2JZ and 1UZs I've kicked around with for the last 12 years the O2 sensor definately has a huge say in what happens in closed loop under 3500rpm as long as the throttle is not near or at WOT.
    Does a 5sfe run an air flow meter? If so, it could also be contaminated - I know on 1UZs in Soarers guys screw them up occasionally with over oiled pod/panel filters.
    GSE20 IS250 - daily
    Quote Originally Posted by manny View Post
    ahh ok. what % throttle does it have an effect up to?
    yah the have an AFM and the EGR is plumbed back to the intake/inlet hoses. Try cleaning thoe out/checking them. And yeah, i meant carby clean- brain fart
    My 1st st162 (3sge) had a rooted 02 sensor the whole time i had it. Idled fine and ran fine just hell rich when gunning it. 5s shoud bethe sma - it probs wouldnt hurt to check it though
    Nov 2007
    Is the CAT part of your headers. On my 1998 5SFE It is. If so it my have dumped a fair bit of oil in there.
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    cat isn't part of the headers/manifold, theres a flexible flange but i doubt there's oil in there as it would have burnt off by now and as there's no more smoke coming out.
    thanks though
    Chiba
    Time for a good Italian tune?
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. Toyota R Engine History
  3. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  4. MA70 --> JZA70 Conversion
