First things first check ALL the fuses with a test light or multimeter.
There is a reverse sensor on the gearbox now it's either gonna be an earth trigger or a positive trigger
The horn has it got an aftermarket steering wheel?? if so check the wiring in behind the steering wheel to see if it's connected up properly and also check for power and earth triggers the horn should be hiding inside thefront bar area
Drive the car with a bit of speed and turn the car almost on full lock doing a u turn if there is cliocking noises then your CV's are stuffed
