here is mine 1JZVVTI in 1999 Hilux
Cobbled up ny own gearbox adapter and engine mounts . Used late model R151 with surf transfer case aluminium flywheel 10inch Hilux clutch Falcon pressure plate modified Rodeo aluminium radiator with fans mounted between radiator and air con condenser The air cleaner behind the battery came from a Suzuki ecu is mounted in the black box to the lower right of the picture custom ss exhaust system . Hilux came with fuel injected motor so had intank pump and wiring for ecu . Had to fit plugs to the 1JZ wiring to plug into existing Hilux wiring loom and wire in a few resistors to fool the ecu into thinking it still had an auto. No sump modifications to front sump . relocated steering damper radiator overflow and battery.Power steering hoses from 4cyl motor fitted to 1JZ pump no mods .Easy as
hahaha
