Results 1 to 13 of 13
Thread: 5SFE wiring issues with later model engine
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    Default 5SFE wiring issues with later model engine
    I've been staring at this for hours now and can't suss it out.
    The vehicle is a 1990 ST184 Celica. I have just swapped in an engine from a 1993 ST184. This would be a series 2 engine so I was expecting there to be some differences.
    I have also got the loom and ECU from the 1993 vehicle so it should have been plain sailing. However I have discovered that there are plugs which don't match up now. I've tried matching colours and had limited success as some of them have completely different colours.
    I figured the engine is so common that someone will be able to advise me here.
    Problem 1. Smashed plug on alternator. Don't know which way the wires go around.
    Here is my best guess but it really is just a guess.
    Problem 2. No plug fits into the ignition coil. There are two candidates which are nearby in the loom but neither of them fit. What is more worrying is that those two plugs do not share wires with the igniter at all which makes me doubt whether they are the right ones at all (On series 1 there are 2 wires in the coil, Black/Orange and White/Blue and both of these are connected to the igniter)
    The coil
    The plug on the old engine
    The two nearby plugs in the new loom which don't fit or share wires
    Problem 3. Reverse light
    (At least I think thats what it is) Here is the plug on the gearbox
    On old engine this goes in with two wires
    Nothing matches on the new loom but this one is nearby. Again , different coloured wires and different plug
    Any help will be much appreciated. I've spent ages putting this thing together and I just have these silly wiring issues left.
    Junior Member Grease Monkey progkamol's Avatar
    Default Re: 5SFE wiring issues with later model engine
    Someone correct me if I'm wrong ... but I think there should be 2 wiring loom come out from the fire wall, the driver's side and the passenger's side. I have had problems before in an RX7 FC (Series 5 motor into a Series 4) where wires doesn't match up. Starting with the wires to the coil packs, it was easily solved on the RX7 by replacing the passenger's side wiring loom which goes direct to the ECU. If you havn't done this already, you might wanna consider pulling the whole loom out ratehr than cut & joints. So the easiest way by sound to solve this problem is to change the whole wiring loom (if you can get them). By saying the easiest way by sound means that its sound easy but its bloody hard to do lol ... Don't know if I'm much help or not but good luck with it ... hope you, or someone here help you, sort it out soon
    Signed
    M4C
    Perth WA
    Nick, I've got an ST204 sitting in the driveway, will go through and try to answer your questions tomorrow, give me a call tomorrow evening.
    May 2008
    I just had a quick look at the car before I left for the office this morning, and I think the distributor may be one with an internal coil. So that would explain why I cant find anything to plug into the coil Although that means theres a whole handful of plugs in the new loom that have nowhere to go!
    I'd be pleased if its internal as its one less thing to worry about.
    The next biggest thing is the plug on the alternator and what order those 3 wires go into the connector.
    Pin 1 = L = Charge Light, Black / Orange Wire
    Pin 2 = IG = Ignition, Yellow Wire
    Pin 3 = S = Sense Wire, White Wire
    Pin numbers are on the back of the plug (cast into the plastic). Currently you need to swap 1 with 3 from what I can see...
    Wire colours come off a JZA80 wiring diagram, but expect them to be the same, I'd be very surprised if they were different, but you have been told
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    The wire colours sound familiar so I would reckon they are right.
    I have this diagram on the alternator but unsure if it is of the connector or of the socket in the alternator itself
    This is the bit of the connector that I have - no pin numbers moulded into it
    So my guess was that the diagram is looking down onto the connector like this
    Which gives
    White (S)
    Yellow (IG)
    Black/Orange (L)
    You are sure there aren't pin numbers where I've marked in the below pic? (I've marked the correct pin numbers in the below pic btw).
    I can take a pic of my tomorrow to show the pin numbers if you want...
    My pin numbers / usage stand as they are. That diagram on the alternator is looking at the male pins on the alternator I believe.
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    Wow, under the grime there were indeed pin number stamped into the plastic plug as you said wilbo
    I got a wiring diagram for 1993 Celica and I think we had the wire colours the wrong way around though so I think my first guess might have been right after all. Since theres so much conflicting information I'll put it up here for a second opinion
    Is correct.
    I have a pic of a JZS161 alternator (EPC confirms) with the same picture on the alternator of the pinout.
    I also have the JZS61 wiring book that tells me 1 = L, 2 = IG, 3 = S.
    The image you posted has the same wire colours as below...
    But if you go off the 2WD wiring then you have Pin 2 = Charge Light, which we have decided is not correct
    4WD seems to line up...
    You should be able to trace back with a multimeter The sense wire will go straight to the battery via some fuses, and knowing which fuse feeds the charge light you will be able to find that also
    Do you have a wiring diagram that shows where the wires go from the alternator? i.e. where they terminate to?
    http://www.celicatech.com/imagearchi...d/Charging.pdf
    From here...
    http://www.celicatech.com/imagearchi...ewd/index.html
    But it does show a round plug however, as opposed to flat...
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    Quote Originally Posted by wilbo666 View Post
    Is correct.
    From here...
    Uh oh ... But your last diagram that you posted says
    Pin 1.S
    Pin 2.L
    Pin 3.IG
    Is that a celica one or an aristo one?
    The diagram I got is this one
    http://rs95.rapidshare.com/files/245...agram_1993.PDF
    And it has this page
    Quote Originally Posted by DrNick View Post
    Pin 1.S
    Pin 2.L
    Pin 3.IG
    It's celica, but the diagram indicates it has a round, not flat alternator plug. Which I stated in my post.
    Hence I believe it to only be useful for perhaps the colours and the fuses to help tracing back with a multimeter.
    The links to that diagram are clearly in my post.
    From here...
    I thought we cleared up what the pin arrangement vs function needed to be already....
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2008
    Getting closer now After various other setbacks I tried cranking the car today but had no luck.
    The car is cranking strongly and no strange noises or anything but I put the charger on just to keep the battery topped up all the same.
    It cranks and doesnt even appear to be trying to start. I pulled an injector clip off and there is pulse going there so its getting fuel, but I saw no evidence of a spark when I pulled off a plug lead and held it near ground.
    I checked codes and there was a code 14 which relates to ignition (no IGF signal for 4 revolutions or something along those lines).
    Now that points to Coil / Igniter / ECU - and all of these were removed from working engine. I did test the resistance of the coil and its within spec. I don't know how to test the igniter.
    Will be looking at it tomorrow so if you have any suggestions for the order to look at things that would be much appreciated.
    With regard to the alternator wiring from my first post. I went with this
    In the off chance that this is wired wrong, would it stop the car from getting spark? I thought that the starting and charging systems were somewhat separate and should not affect each other, but I saw this thread http://www.toymods.net/forums/showthread.php?t=45665 where someone suggested alternator as a cause for no spark when starting.
    May 2006
    Is the map sensor plugged in?
  1. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  2. MA70 --> JZA70 Conversion
  3. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  4. Toyota Model Codes Explained
    By wagonist in forum FAQ
    Last Post: 14-10-2005, 09:47 PM
