Results 1 to 10 of 10
Thread: Celica heating issues
    Dec 2009
    Default Celica heating issues
    Hi guys,
    I'm new to the toyota car scene,
    Anyways, my car seems to be overheating and the heater doesnt seem to be working.
    Also, the check engine light comes on when it gets hot, when i turn the car off there is a hissing noise coming from the driver side engine bay.
    I'm gonna top up the coolant tomorrow and see if that fixes the overheating issue. and check for any leaks.
    Any advice on why the check engine light (i dont know the error code) is on or how to fix this issue?
    Thanks in advance
    The car is a Gen 7 celica
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Default Re: Celica heating issues
    Definitely check your coolant level as it could be dry...check that hissing noise probably find it might be a water leak.
    check radiator cap (may not be pressurising thus blowing out the coolant and over heating)
    also check thermostat operation.
    or just take it to the mechanic if you dont know what your doing.
    RA23 - Twincharged
    JZZ20 - Daily
    Dec 2009
    Quote Originally Posted by kickstartRA28 View Post
    yeah gonna top up coolant tomorrow, will check hoses for leaks
    Dec 2009
    Quote Originally Posted by Kedderz View Post
    if the topping up the coolant wont work, i'll flush it all out and change the thermostat to see if its the thermostat.
    Junior Member Grease Monkey KENut's Avatar
    Jun 2009
    If the heater isnt working then I'm guessing its blocked.
    Flush the system thoroughly.
    What colour is the coolant? rusty? any oily scum?
    Hissing noise may be steam coming out the overflow - as said check the radiator cap is pressurising the system
    Maybe the check light is indicating overheat
    Junior Member Grease Monkey progkamol's Avatar
    Sounds like thermostat is not opening ... but yeah, like other people said, check your coolant level, radiator cap and overflow bottle etc and also check to see if there is any visible leak...
    If all this doesn't solve the problem for you, which I don't really think it will then you'll need to remove the thermostat housing, flush it and change a new thermostat.
    Signed
    M4C
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    that hissing noise is gonna be a leak guaranteed what you need to do is fill it up pressure rise the system and see where its leaking from and fix it asap..
    Achin' 4 some tyre bakin' Backyard Mechanic
    and your heater not working is possibly a sign that there is f-a water in your cooling system. how long has it been overheating?
    Johnny Cash is my Navigator.
    Tallahassee, FL USofA
    Quote Originally Posted by kelvin View Post
    First, how about checking levels & any leaks & hissing TODAY, then tomorrow you can play on the WWW.
    Hope you haven't toasted it already!
  1. Celica 3SGE into SW20
    By Roman in forum Tech and Conversions
    Last Post: 18-10-2006, 12:06 PM
