Results 1 to 6 of 6
Thread: 7M alternator issue
    May 2008
    Default 7M alternator issue
    whats up guys
    just finshed fixing the Headgasket on a 7MGTE now when I attach the battery to the car a little nut looking thing at the back of the alternator starts to hiss and when the car is running was glowing yellow WTF could be doing this? all earths look
    1992 - JZA70 STOCK - SOLD
    Default Re: 7M alternator issue
    got all the right wires going to the right place? havent mixed up positive and negative somewhere along the line?
    May 2008
    ok its happend again....hooked up battery and within seconds there is a hissing noise near the "B" nut on the back of the alternator by "nut" i mean the tiny nut. and its started to glow yellow and get very freaking hot!! wires remined cool though. all I did for the BHG was take off the wiring loom from engien intake manifold and head.............................................. ................................................
    Junior Member Grease Monkey progkamol's Avatar
    I would check the wiring loom that you initially took off when you did your head, might be a good idea to remove them and check it then wire it back up again and try...
    Signed
    M4C
    disconnect wires from the B nut and make sure none of the wires are earthed.
    May 2008
    well I suspect its the alarm wiring causing it will have to check...all wiring I took from engine was put back into its right place ill grab a pic of the alternator back part tis burnt! mind you while this was happening the wiring going to alternator didnt get hot etc
  1. 1JZ vs 7M alternator useful info and pics
    By Ribfeast in forum Tech and Conversions
    Last Post: 22-06-2009, 04:10 PM
  2. 7m and 1g injectors?
    By hypo23 in forum Tech and Conversions
    Last Post: 05-10-2006, 01:28 PM
  3. 6M and 7M differences???
    By fatboy13 in forum Tech and Conversions
    Last Post: 10-01-2006, 07:20 PM
