Results 16 to 20 of 20
Thread: TA22 disc brake conversion
    Mar 2009
    Default Re: TA22 disc brake conversion
    Quote Originally Posted by old_school_jap1 View Post
    You need a 51mm inner diameter sleeve for the xt130 strut
    Im doing this brake upgrade at the moment, where whould i find an inner sleeve for the ta22 shock into the xt130 strut?
    Hi.
    the thing old_school_jap is talking about is the coilover sleeve that goes on the outside for coilovers. If you're meaning the shock absorber to go into the xt130 strut casing then people use the sw20 mr2 rears. That is if you cut the strut casing down as the mr2 is a short stroke shock.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Quote Originally Posted by Hen View Post
    A friend put the CPH setup in his TA22 a few years ago. It all fitted up fine as far as I can recall. Possibly even used TA22 King springs which fitted OK into the XT130 lower perch.
    However when the car was at a reasonable height (not in the weeds, but a bit lowered) he had only 30mm of suspension travel before he hit the bump stop. I'm afraid I can't remember the exact details, but keep an eye on things when you're assembling.
    Hen
    The TA22 spring perch sits lower on the strut than the XT130. ie TA22 springs will be too long when fitted to a Corona strut. You can buy XT130 lowered springs from KINGS springs.
    Chronologic history of TA22 brake upgrades.
    The first brake upgrade on a TA22 celica, was to simply swap the RA23 strut and brakes into them, obviously the the strut top had to be swapped over.
    The second upgrade was to install XT130 Corona strut and brakes as a whole assembly, again changeing the strut top.
    The third iteration was the inclusion of RA60 vented rotors on the Corona strut, this necessitated the fitment of a spacer in the caliper to accomodate the extra width of the vented disc.
    The fourth generation brake upgrade again used the Corona strut, RA60 vented disc, and the MX62 Cressida caliper. This was a bolt up job with simply fattenning of the caliper mount ears required. This setup has been used on Celica's with in excess of 200rwkw for street use.
    The fifth generation brake upgrade was the Pug/HiLux, again using the XT130 strut. The ideal budget street and track setup.
    The sixth iteration is the Hoppers Stoppers kit, fairly expensive in comparison to all the others, but it works extremely well.
    cheers Chuck.
    MS51Crown Coupe,
    But is the Hoppers Stoppers better value than the other options?
    seeyuzz
    river
    For interests sake I rang Hoppers Stoppers, and spoke to them about their brake upgrade kit for the Celica. It won't work for me because you need at least 16-inch Simmons to fit the kit. This is a problem with the Simmons wheels, as the bolts that hold the centre to the rim protude and hit the calipers.
    Their kit only fits on Simmons that are 16inchs or larger.
    seeyuzz
    river
    By The Witzl in forum FAQ
  2. TA22 Manual Conversion Write-Up
    By kugzs in forum Tech and Conversions
    Last Post: 08-09-2006, 01:44 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
    Last Post: 08-09-2005, 01:27 PM
