Results 16 to 30 of 31
Thread: 1g-gte into Hilux - ADDED PICS OF PROGRESS
    Jan 2009
    Default Re: 1g-gte into Hilux - Q's
    Mate, just mod the bracket off the gearbox crossmember. The W58 box uses the same gearbox rubber as a Lux. So just cut, move to where you need it, weld it, & abit of paint, and ya there. I think I only put mine down an inch, if I remember. Hope that helps.
    Junior Member Grease Monkey 81hilux09's Avatar
    Apr 2009
    almost got the gearbox mount done now, just have to level out the engine to get the bellhousing level then i can mark it and get it welded.
    thanks mate
    Jan 2009
    No worries champ, anytime.
    T'ville, QLD
    have you looked at any of the ra2* => 1ggte conversion pages? cos ill bet that an 18r slots right into an Rn 41
    2T out 4A in....
    Quote Originally Posted by skiddz View Post
    wtf? they came with 18r's standard. RN41s have the same engine brackets as ra40s I believe, so it should be a bolt in deal with the right brackets on the 1ggte
    Apr 2009
    anyone know the size of the std intercooler inlet pipe size??
    Apr 2009
    just a few pics of the progression of the conversion..
    i have the engine/gearbox bolted in now.
    have to do : intercooler piping, radiator pluming, pwr steering lines, alternator wiring, ign/fuel wiring, move battery to other side of engine bay, install seats and shorten tailshaft with new yoke thing on the end for new gearbox.
    THanks
    Curt
    Apr 2009
    more pics.
    Apr 2009
    Default Re: 1g-gte into Hilux - ADDED PICS OF PROGRESS
    oil fitting to get rid of the stock oil cooler for the oil filter which didnt fit
    i fully did the front end up as well, doing ball joints, shocks, disc brake conversion.
    radiator had the outlets moved to suit the thermostat housing
    engine in
    intercooler piping sorted
    dodgy cheap arse bov from the states, only got it becuase it came with the adapter pipe
    grill on, fit like a glove after removing small plastic mounts bits in the middle
    a MX83 cressida master cylinder fitted, gives more room for the pipe to go into the turbos as the front brake line output goes up instead of into the engine
    Apr 2009
    also did a power steering conversion and used a MX83 cressida pr steering hose and one off a 4 runner for the low pressure side.
    another one of the master cylinder.
    so thats about it for now (after a day of panic becuase i sliced my hand open on a piece of steel and had 3 stitchers on my index fingers knuckle)
    need to get starter motor wired, alternator and the 3 wires for the ecu to get the thing fired up!!
    Apr 2009
    Apr 2009
    the carnage!!
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    looks good im doin the same conversion but not runnin power steer and a single turbo gonna be fun to put in ha ha
    highly underrated Backyard Mechanic
    Feb 2010
    lol looks like he had enough after it bit him
    RT104 with 4AGTE
    Some assembly required
    Apr 2009
    im still here. had to sell when i got a new job. couldnt keep up the fuel bill
  1. Swapping out Hilux 4 speed for a 5 speed....
    By BlueDream in forum Tech and Conversions
    Last Post: 20-03-2009, 10:35 PM
  2. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 08:27 PM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
